1 - 14 of 14 Posts
· Registered
Can anybody tell me what the latest software and map versions are please. Trying up update mine but says I have latest versions, but not updated for a year, so thought the versions I have downloaded from fb group would be a update for mine.
· Registered
This should be the update you need, worked on my wife's late 2018 i30, which has the same "gen 5" head unit. Ask there for confirmation or help.
· Registered
Thanks. Will give it a go.
· Registered
Hi Richard, this is my FE registered Feb 2020. First service in Jan 21. No update by dealer. Same as before service. Latest software??!
The numbers on my version, installed from a download link posted on this forum about a year ago, all seem to be later. One of the more interesting changes was the ability to display the actual GPS speed on the map screen, top left below the speed limit. Settings> Navigation > Display > Information > Display vehicle speed. The original FE version did not have this.
· Registered
Thank you Richard, I shall see if I can find in the settings if there is ' display vehicle speed'
Will let you know
· Registered
Hi Richard
My settings- navigation - display
Then that's the end, hence it's most likely the very old original Fe system software.
Back to dealer
thanks
· Registered
This is the version that was installed on mine at the service by the local dealer.
I already had updated mine previously using the downloads from this forum last year and used a blank sd card so if the download was duff I could pop the old kia sd card back in. As the update was successfull I just left the new sd card with the new maps in the infotainment unit as you need to do this for the maps to work
So I was surprised when the dealer told me the he was not going to give me the update because there was a "non genuine" kia sd card in the infotainment slot. So how much does a new kia sd card cost I asked? They cost €300!!! So with that i told him the original sd card that came with the car was in the glove box....
So if you do a DIY upgrade make sure that you keep the original kia sd card in the car and dont throw it away. You will need it for your free map upgrade from kia later on.
Dbrab
141735
1 - 14 of 14 Posts
