1 - 20 of 53 Posts
Taking family of 4 + luggage from SE London to Torquay. In the snow. Running the early software. Updates to follow...
Technically yes, but we’re going to stop around Amesbury where there’s a choice of Osprey and Polar...
Reactions: Todor
143269
standard M25
Reactions: EV Believer
Discussion Starter · #7 ·
2.7mpkwh so far. Not great but the conditions aren’t either! Bailed at Fleet as the kids are already bored and pleasantly surprised to find the Ecotricity CCS is working.
143270
still not sure what to make of this “mph” measurement.
Good luck!
mph is a reasonable measure for charging speed. The problem with kW is that it takes no account of the relative efficiency of different vehicles - an Audi e-tron can charge at 150kW and a kia e-Niro at 75kW, but in mph terms they're almost identical as the Audi averages around 2.5mi/kWh and the kia is closer to 5. It's arguably the most important measure of charging speed when you're actually on a journey.
Go for Route 303 restaurant as your second stop - american diner lunch and 100kW charging! EX14 9ND.
Kona64
I thought the mph of charging meant " stay here one hour and you will have increased range by 106 miles "
Therefore if you bail after 30mins your range will have gone up 53 miles.
This is more a useful indicator than " 63kw" on a display of a 150kw charger.
Whilst this also is telling you how much electricity is going in the vehicle, it is bloomin' useless to most people
Give us both figures! 😊
i3 120Ah->Kona 64kWh->e208->ID.3 Family->Model 3 60kWh LFP
Miles per hour is a bit silly though because hardly anyone is going to stay plugged into a rapid for an hour, and the mph figure is just a snapshot of the rate at that particular moment - so extrapolating doesn’t work on almost all cars, because they don’t have 'a flat curve'.
More useful would be a screen that said (based on what the car knows about its own charging curve and the current efficiency) something along the lines of 10 mins more charging will add x miles, 20 mins will add y, 30 will add z... etc
533 miles in the car in one hour ?!?!?!?
#EverSoSlightlyJealous
That's an instantaneous rate though, at close to peak charging speed (on that charger anyway - that was a 120kW V2). Of course it drops later on, but I went from 5% to 70% in 20 minutes, which is about 120-150 miles added range, so average 360-450mi/hr over the charge. Above 70 it drops further of course. On a high-power charger the ID3 won't be far off that kind of rate.
More useful would be a screen that said (based on the what the car knows about its own charging curve and the current efficiency) something along the lines of 10 mins more charging will add x miles, 20 mins will add y, 30 will add z... etc
Yes - Tesla sort of do that with the "time remaining" being to the charge limit that you have set. If you have a nav destination set then it will tell you time remaining until you have enough to get to that nav destination.
Nissan also in the 40 and 62kWh Leaf show how much time remaining to reach various charge levels:
143278
Kona64
I think they nailed it with this display --- so much useful information in the same part of the dashboard.
Discussion Starter · #17 ·
Update: the A303 is as horrific as you would expect. Now charging at Wincanton Instavolt next to an e-tron while we pop into McDo.
143286
Reactions: OB1CCFC and i-s
Discussion Starter · #18 ·
(no way of making the photo the right way around!)
This is a great place to stop - 2 Osprey chargers right opposite too.
Reactions: roadhawk and alegar
Yes the Kona (and I assume the Niro and Soul) do that too - the time to reach a SoC point is not quite the same though as the driver then has to work out for themselves (or guess from experience, or use ABRP) what the range will be at the target SoC. ie. they don’t say "x mins to get to y%, at which point the GOM will say z miles".
Of course, like in many aspects of the software side of things (and EV specific hardware too) Tesla are currently leading the field (with some others like Polestar/Google starting to close the gap).
1 - 20 of 53 Posts
