I'm thinking of fitting the Dash Cam I used to have in my old Ampera into the Kona. In the Ampera it was pretty simple as there was an accessory socket located in the center of the dash, in a small bin, so no cables trailing.
I've read a few posts and it's been suggested that the camera could be connected to the red and black wires in the light unit above the windscreen. I've had a quick look, so anyone any idea which ones I should be wiring into? The camera I have starts recording when the ignition switches on and stops recording around two minutes after the ignitian is turned off, so I'm not really after a permanent supply, but that may change if I manage to get one of these 360 cameras which will take an image every couple of seconds when the car is parked up.
