1 - 17 of 17 Posts
Corsa-e Elite Nav 70 reg
We are picking up our new Corsa-e in a few days and were looking forward to getting a new Pod Point charger to replace our 7 year old Chargemaster. A lot has changed in 7 years. The price of the charger is included in the car price.
I contacted Pod Point after their online form insisted on charging £350 for installation as we had already had a government grant for the original charger. As there would be so little installation required, it would just be replacing the existing charger, I thought there would be little or no charge. I filled in another online form and supplied photos of the existing installation.
Several days passed then I got a phone call from Pod Point. I explained our situation, but the outcome was that they would not waive or even reduce the installation fee. I mentioned that in that case they would be losing a substantial payment from Vauxhall, but he would not budge.
I'm now trying to negotiate a discount on the car, as Vauxhall will be saving some money.
There are going to be a lot of people in the same boat as they move to their second or subsequent EV. Perhaps a 2 tier installation fee might be the answer, depending on whether it's a new installation or just a replacement?
I can just hear the electrician when he comes to install a replacement charger: 'You've had the cowboys in here... This wiring & consumer unit will all need replacing, so I'm afraid it will cost the same as if we'd done it from scratch.'
Yes but. Does the installation comply with current "wiring regs"...?
Yes, I suppose that you're both right; the 2 tier pricing idea is a non-starter for the reasons you've mentioned. :(
Get them to install a 32A commando then you can use it as a portable appliance :) Steel hat on!
I would pay the 350 tbh, thats not a bad price to get a new unit installed. Its cost me around that by doing the work myself and using a used Podpoint unit, An electrian will charge £120-150 just for certifying an installation you have done yourself.
Whats wrong with your chargemaster, if its a 7kw unit, i'd stick with that.
Discussion Starter #7 (Edited)
It's 7 years old; modern chargers have better safety features and connectivity, including charging options, e.g. from an app. But the Chargemaster will do for the time being. If I manage to get some compensation from Vauxhall, that will be a bonus, I'll then consider what to do in the future.
TBH I hadn't considered changing the charger, but when offered a 'free' charger as part of the deal with the new car, it seemed a good idea.
You cant use the grant to replace an old charger, you could however get another one put in, madness I know but it is what it is. £350 sounds cheap, I’d go for that!
Can you get Vauxhall/Pod Point to just give you the charger? Get a local electrician to fit it, they won't rip you off like the OLEV approved ones.
Discussion Starter #10
I asked if they could just supply the charger, but they wouldn't do it.
If at same address, You can only get the Second grant if you can prove owning both cars concurrently , and that your system is capable of using both.
Guess a little know fact but when you sell a car used for A grant you need to let OLEV know.
just paid £350 for my free Audi Pod-Point... he didn’t reuse any of the old wiring ,( I had removed the unit myself) rather added a new CU from the tails
Reactions: andyfras
EVEZY code -£50 off: d409e
Where's that mentioned? All I can see is a 6 months min requirement.
"If the customer’s circumstances change or they no longer have use of their electric vehicle before the minimum 6-month keepership period, the customer must inform OLEV via [email protected]."
Thanks, either I read it wrong or was basing it on a previous version.
Isn't the chargemaster ran from your consumer unit with a earth rod?
Pod point can't run from there unless
they put in a adjacent CU.
Discussion Starter #15
I have a separate 'garage unit' with a 40A RCB and 40A breaker which was installed with the Chargemaster.
Yep they can run from that if it's tested, only take a min to test it, they'd probably want to run a cable for fuse saver.
But there never gonna budge mate
1 - 17 of 17 Posts
