1 - 5 of 5 Posts
Hi All,
first timer here! Just had this pop up in my eGolf. Can anyone shed some light on this and why did it happen?
135925
Thank you all in advance.
Kia Soul EV 2020
Check the front facing radar? The black flat square on the low front bumper? Probably below the number plate?
Check for dirt, or misalignment? Loose?
Reactions: Siufaye98
Agree, check theres no obvious physical problem with the radar.
Mine sometimes flashes up when I'm driving on twisty, undulating roads or about to go up a steep uphill. Thankfully it's only slammed on the brakes once, and that was when the car ahead of me slammed on their brakes.
Thanks All! The light has switched off and can’t see anything obvious obstructing the radar. Will take it back to garage if it happens again.
Isn't that the adaptive cruise control doing what it's supposed to do? i.e. keep you at the safe distance (which you can set) even though you have set the speed higher?
1 - 5 of 5 Posts
