1 - 4 of 4 Posts
Yes, but it isn't quite as good for two reasons. Firstly it doesn't share, it just cuts power to the second unit which the second EVSE/car may not appreciate. Secondly, it only switches to the second unit once consumption goes below 3kW which will includes most of the rundown charging rate at the battery balances - meaning that there will be less time available for the second one to charge.
I don't think it's a good solution for 2 chargers, just a quick & simple fix where other loads like showers can suspend charging. Any car should be able to cope correctly with power interruption during charging.
A possible enhancement is to wire it so thet it just interrupts the CP line instead of power, to avoid the need to switch the high current.
Yeah, as others have said load balancing or monitoring is a far better solution. The Podpoint units have (and I think fit as standard) load sensing. They are an affordable solution for people with high, occasional house loads such as showers, electric heating, etc. or want two points. I suspect other manufacturers will add the features as more people have multiple EVs and want two charging points.
1 - 4 of 4 Posts
