Hi, I've recently noticed that my 1st Gen 24kw doesn't charge to 100% (and i've disabled the 'charge to 80%' on the timer). It goes to around 90% - not 100. This is on both the granny cable and a 3.3Kw (?) home charging point.
I also saw different 12V battery readings (it's 1 year old) once is was over 13V and the next time under 12V. Odd, possibly unrelated. Also, it's reporting low battery in the key - but only sometimes.
I ran Leafspy and saw this error code, but it then disappeared.
Any suggestions ?
Currently my plan is to disconnect the 12V battery, and see if this fixes the problem; then i might charge it on a regular old battery charger.
I'd like to get the full 100% charge, as on occasion i want to go 60-70 miles, which is getting to the limits of my older battery (78%SOH)
Any suggestions ?
