Hello, thanks for that - I updated the ad!Hi.. some other info required.. what battery size. How old is she..
This is an old 22kWh battery model. So it's only got a type 2 connector.I am guessing it has a type 2 plug (or is it one with a CCS plug) if it comes with a type 2 cable?
It's got the chameleon charger. It can charge at 7kW AC (and beyond, all the way up to 43kW with 3-Phase power supply)Does it have a 3.3kW or 7kW onboard charger when plugged into a home wallbox charger?
Up to 43kW Rapid charging, but on AC only. No DC/CCS Support.Can the Q210 model charge at 40kW DC?
You would have to contact Renault directly to get an idea of the purchase value. From what I have seen the prices aren't terrible, but you will probably be paying a few thousand for it. You'd have to work out how long you plan to keep the car, if you value a lifetime battery warranty, and what the costs of each would be for your mileage. I'll leave it for OP To reply in case they have enquired themselves recently.Any idea how much to buy the battery out right from Renault?
Hi there.You would have to contact Renault directly to get an idea of the purchase value. From what I have seen the prices aren't terrible, but you will probably be paying a few thousand for it. You'd have to work out how long you plan to keep the car, if you value a lifetime battery warranty, and what the costs of each would be for your mileage. I'll leave it for OP To reply in case they have enquired themselves recently.
