1 - 5 of 5 Posts
· Registered
2021 Corsa-e
Mine came with a granny charger, but ironically it has an MG logo on it.
I suppose its because Opel doesn't supply one, and the local dealer also sells MGs, so they just give you an MG one.
Anyways, it's rated at 10amp @ 230v.
· Registered
Corsa-e 2020
Does anyone have a image of the supplied corsa E charger? I want to know what its rated at.
The label on the back/front/side/wherever would be amazing if anyone could help
In the UK, the Corsa-e isn't supplied with an "E charger". It comes with a type 2 to type 2 cable which you use to connect to an external charger, wither an untethered charger at home or a public one. If you want to use a "Granny charger", one that plugs in to your home domestic socket then I can recommend this one which is one of the cheapest you will find: Masterplug 10A 2.3kW Mode 2 Type 2 Socket Electric Vehicle Charging Cable 5m
I used one for 6 weeks with my Corsa-e before my PodPoint was installed. Had no problems whatsoever with it.
1 - 5 of 5 Posts
