41 - 60 of 94 Posts
If you need a cable to charge ampera on public charger but dont want to spend 150+ then u can build it ur self for much less. Get granny charger that died cut off cabel near the charger and connect cable to standard type 2 charging plug.
No electronic element needed.
Car will directly comunicate to public evse and u will get 16 amps charging current and 3,4kw of power. Car battery will be from empty to full in 2h and 40 min. I can draw a connection diagram for diy guys....
Regards
Be aware fitting type 2 plugs (and 1 for that matter) needs a professional crimp tool for the pins. These are not cheap like the diy ones!
For me, the real advantage of owning an Ampera is that I just don't need to worry about public charging points. I always charge overnight at home on Economy 7 and very occasional I may plug in at work for a top-up. When the usable battery power is exhausted the engine takes over. Absolutely no need to spend time and money at public charging points.
Reactions: RickMGoldie
Hmm, I think 2h 40mins is a bit optimistic! best I've seen out of my 32A EVSE is 14A drawn, and around 4.5 hours for a full charge.
If its summer arround 28 c in battery then with 3.4kw (16 amp) 3x3,4kw=10,2kwh , so full battery (not new) should get just under 3 h charging time. It works with my ampera and i can still get with full charge arround 72km distance with ultragentle driving. Ofcourse when its colder then totally different story. Heating battery, heating cabin, cold tyres....
Charging isn't 100% efficient. I find my Ampy takes 12 kWh from the grid, to give me my 10.4 kWh useable. 235V at 14A will take 3.65 hours to achieve this 12 kWh. But the current diminishes a bit as the battery voltage level rises towards its max of 400V or thereabouts, and the BMS does some cell balancing stuff, so in practice a full charge tends to take over 4 hours to finish.
If you drive ultra, ultra gently, it's possible to achieve 96 km on one charge! See the "60 Mile Club" thread ! But for this, you have to not exceed 65 kph, and averagr more like 35 kph, on some flattish road in midsummer where here are no other cars or tractors or lorries to get annoyed by how slowly you're going! :)
One thing to note about this car is that it only supports specific PWM settings. So it will not work correctly with variable charge rate EVSEs such as the Myenergi Zappi (although it is fine at its max of 3.6kW). Interestingly it is possible to set the PWM signal so that it will charge at a lower rate than the protocol's normally accepted minimum of 6A.
Thnaks for the previous answers, im getting a home socket installed next week, quite a lot of digging required!
Another question.. quite a lot of public chargers have tethered cables. I only have my type 1 to type 2 female cable so can't hook up. Is there some sort of type 2 male to male adaptor available or some other way of hooking up?
Cheers
Ampera aka IGOR
Tesla Model 3 P
The chargers with cables attached will most probably (well I've yet to see a fast charger with a cable attached other than when one was left accidentally or could not be removed) are rapid chargers that the Ampera can't use. The cable you have, I think, will be a type 2 plug to a type 1 plug. This is for fast charger sockets (type 2) which you plug your cable into once you have plugged the other end (type 1) into the car once you have activated the charger/
The usual tethered charger is a Rapid, the DC part can not be used by the Amp. The AC tethered on a rapid in theory could be used with an adapter but costs can be huge as many are by time. The adapters are also not approved for charging cars.
The other tethered ones are Tesla Destination chargers normally at hotels, the white ones have a type 2 plug and can not be used by type 1 cars like the Ampera , the red ones are Tesla only.
Slow (3.6kW) and Fast(7.2 to 22kW) chargers found in carparks and on the roadside are socketed and your T2 to T1 cable is fine. just watch out for costs as the Ampera charges at 3.3kW which is about 12 miles per hour, less in winter. Sometimes its cheaper to use petrol than charge when out and about!
In London "Source London" has some tethered Type 1 units (with T2 sockets) intended for their hire cars. These are very expensive to use for charging and should be treated as on street parking with added charging.
What do people think is the best strategy for getting a home charge point installed? While the Ampera is type 1, any future EV we get will be Type 2.
  1. Unethered charge point - will have to buy a cable for the Ampera - an extra circa £150+? This cable will allow us to use public chargers also. Will possibly need to buy a charge cable for any future EV we get also.
  2. Tethered type 2 charge point - will have to buy an adaptor for the Ampera - an extra circa £150? Still would need to buy a cable to use public chargers. Won't have to buy a new cable if get a future EV but most cars come with them anyway?
MG5 and Chevy Volt
I'd go for untethered. You can sell the type 1 cable when you sell the Ampera, and the new car will probably come with a type 2 cable.
Ampera aka IGOR
Tesla Model 3 P
My first charger for the Ampera was tethered, I did not know any better and just took what was recommended by the Energy Savings Trust in Scotland which was a tethered type 1 Rolec but with wiring capable of 32 amp (as they said to futureproof the installation but now the type 1 plug use is dwindling) installed by SSE. I also had a public charging cable too, this was part of a Vauxhall promotion at the time I bought the car and I used it that much then when it packed in I bought a replacement as soon as possible as I used public charging twice daily. Tethered is much easier to handle when wet as you don't need to worry about moisture getting in the car and you just need to plug in the one end so quicker too. My replacement charger (I needed a type 2 plug for the new car) is a socketed version as my brother can plug in my old Ampera when he visits. I have two cables for the new car, one stays plugged into the charger and the other cable is the boot of the car.
Untethered also lets you get a cable that's longer (10m) than most tethered ones are; can be useful if several cars on your drive; also take the cable with you on trips, and a long one may just let you charge at some supermarket where Ices have parked right by the EVSE and you're a few spaces away.
I’d go for untethered too. Took me a while to understand all the options when I was making the decision, but my thinking was future proofing. Looks neater too IMHO. I did buy a type 2 to type 1 adapter that I have used occasionally with a type 2 public tethered point, but this is quite short so easy enough to carry in the boot. Useful from time to time, but I use only when there’s no option. Funnily enough, as HandAndy mentions I’ve used this with a 10m type 2 both ends cable at work because some ICE drivers pinch the EV slots.
With regards to charging, I have mine in my garage always plugged in, plug switch on.
Is this the right thing to do? I think it has improved my range (by conditioning the battery?, now getting 38 miles range, used to get 25ish), but wondering if I am using too much electricity. Or should I switch off after charging? Also if at thunderstorm is going on, i guess it's best to unplug completely?
No harm in leaving Ampera always charging as it doesn't charge to 100% anyway. Your estimated range increases based on driving style and temperature of battery when departing.
Unplugging in a thunderstorm isn't a bad idea. Leave it plugged in if particularly hot or cold weather and it'll heat and cool the batteries appropriately.
ok thx, i did pop in my garage at night, and the Ampera was making all sorts of noises, like it was having its own party! I'm sure this is using electricity, even though fully charged.
Ampera aka IGOR
Tesla Model 3 P
It will be the pumps circulating coolant to keep the battery happy, quite normal, or as a salesman would say TADTS.
Typically, a full charge takes 11.5kWh. A preheat uses upto 1kWh (heat is max 6kW for 10 minutes). Can imagine it would use much when in a garage.
41 - 60 of 94 Posts
