1 - 18 of 18 Posts
The Kia EV6 is an innovative EV and the associated Kia Connect remote app has some excellent features.
Firstly from the app home screen Remote you can start climate control remotely setting the desired Climate Settings temperature
Font Circle Brand Magenta Rectangle
Not only that, but you can also use Scheduled climate control to start climatisation in the vehicle 30 minutes before a departure time you set and also set the windscreen to defrost.
Font Material property Rectangle Screenshot Magenta
Simply set your Next Departure Time in the Scheduled charging submenu 'Scheduled Climate Control" with your requirements.
Rectangle Font Parallel Magenta Number
And for further convenience, you can choose to the following options individually to suit your preferences
  • Defrost On - for the front windscreen
  • Side mirrors + Rear window heating
  • Steering wheel heating
Rectangle Font Parallel Screenshot Number
So on those cold icy mornings, unlike an ICE vehicle there is no need to stand in the cold and de-ice your vehicle. You can head out to your car at the pre-schedule time with front windscreen, rear windscreen and the side mirrors defrosted, the car interior heated to your required temperature, and the steering wheel toasty warm ready for your journey ahead.
Better yet, this is a standard feature on all UK models (Air, GT Line and GT Line S). The screen shots shown are from the iOS app version 2.1.3 but the same great features are available on the Android Kia Connect App.
Additional details of this innovative feature available in the Kia EV6 Owners Manual supplied with your vehicle (pages 2-8 to 2-9).
If only.....:sneaky:
How many departure times can you set at any 1 time?
Can you set a time for every day of the week and have it repeat continuously?
Tested this out yesterday, set heating at 25C, got an alert to say the car has finished pre heating, car was cold but it had done something, there was warm ish air and plenty of condensation inside on windows.... strange. Pre heat only works for 10mins right?. Did the car try and take the temp to 25C but ran out of time and stopped before it hit 25C
Just tested out again at a temp that’s not so hard for the car to get to, 23C. Set in the app, started the heating process. Could hear the car was on, fans, clicking sound. After 7 mins got an alert saying nearly finished. Then after 10mins or so I got an alert saying it was finished. Went to the car, opened doors and it was very hot inside and like a jungle with condensation. At least heating works on. Schedule or from app. Wing mirrors seem warm, back windows seem warm, windscreen hot. All windows would need a wipe before driving. EV6 has a dehumidifier right? Read something about it. Anyway, if I then now set to 27C the car is unlikely to get to that temp on a cold morning in 10mins...
While showing images, I seem to have two boot lights... they don't turn in though. Any ideas?. See last image.
Car Vehicle Automotive lighting Hood Sky
Car Tire Wheel Vehicle Land vehicle
Grille Vehicle Automotive lighting Hood Motor vehicle
Yep - mine just blows cold air mists up window on the inside and I am then having to wipe them down with a microfibre so I can see to drive 😂 At least the steering wheel heats up.
Does this mean if there is condensation your having to wipe away, it means the car is showing moisture-filled air or is hot air meeting a cold surface in the car and it is kind of working?.
Gotcha would be great if they could be used for actual real lighting when the boot is open and not just glow.
Nope sadly means cold moisture filled air coming into car steams it up. If you get in car with no pre-heat start and turn on front demist no issues.
. View attachment 155628
Number plate lights!
HA! I wish that was true!
I could do that with my MINI, alas not possible with my car built 1st September, had 3 infotainment updates, had 3 App updates had the ABS/TC update and the heating update HVAC STILL not right!
This last week I have tried on 3 separate days “pre heat” HRW, Wheel & mirrors heat up, cabin still cold, drove away from home, no heat despite turned up to 27 degrees.
I am getting so pi55ed off at KIAs inability to resolve this issue. It appears they are now not even responding to my emails (now 4 to Pall Philpott)
I wish I knew how to get them to resolve the issues!
Oh does anyone know how to get cool air out of the centre vents? All I can get is a trickle of warm air when heat IS available. I am unable to get a stream of cold air to my face. This was a feature available in a 1968 Ford Escort, why is it not there in a 2021 £52K+ car?
Discussion Starter · #15 ·
Hi Gordon,
I thought I would offer some empathy as a Kia EV6 owner who is also experiencing a fault with the climate control. For me it works fine when in the car and thankfully delivers heating, but neither the manual remote activation of climate control, nor the scheduled activation of the climate control work. So having gone from a 2017 Nissan Leaf where the scheduled control worked faultlessly (and de-icing was a thing of the past), I am having to sit in the car for 10 minutes on icy mornings to defrost the front window (note: the scheduled rear window defrost, and heated steering wheel does seem to work, but less important that the front windscreen defrosting).
The best thing to do I think is to report to your Kia dealer, outline the fault and allow them to fix it. The main positive things for my situation are:
  • This is a fault as the car is designed to for a pre-climate function.
  • The heating does work when activated from the car so I think this is probably more a software fault than a fundamental issue with the heating.
From experience of a software/app issue in a previous car (a new model Audi RS4) these things can take some time to fix (in that case it was 4 months), and while it is frustrating that a brand new model has a fault like this, evidence suggests that this a widespread problem - not just an issue with your car which should put pressure on Kia to fix for everyone.
I hope this is a helpful post, and I'll update this thread if my dealer has success resolving the issue.
All the best,
Warwick Boy
There is a decent work around found by EVOdessey ( Brian Devine ) to get preheat working . Basically make sure climate control is set to decent temp and on auto before you switch off car . Then when you want to preheat, use remote keyfob , lock car then within 4 secs press and hold " car on " button . Looks like a circle with arrow at end. This switches on car and activates heating for 10 mins. Caveat is you need to be within key range of car , but his video shows it working form upstairs bedroom. Other thing is it can't be plugged into charger as car won't switch on !
Link to his video
Seems to work with my GT Line, remote start button is on side of my fob as no driving controls on my level.
Agree with all of the above. I (apparently) have a new inverter and (apparently) the latest software..but remote and schedule pre heat still doesn't work.
Remote start as detailed by EvOdessey does work..half decent workaround for now.
Still don't know if anyone - especially people who also have new inverter - has got the remote pre heat working. Is everyone in the same boat or just select cars?
1 - 18 of 18 Posts
