1 - 3 of 3 Posts
I found out the other day that if you pull the bottom of the headrest towards the front of the car it is adjustable. If you pull it all the way you can then push it back to its starting position. Had the car nearly two years and only just found this:rolleyes: This is the Electron model not sure if it will be the same on the Positiv.
It's the same on both. Have you found the other height adjustment button yet? I guess I must have read it in the manual? Which is why I have to agree with comments saying the BMW i3 should have a physical manual, as the digital help system makes it much harder to find out these details.
1 - 3 of 3 Posts
