1 - 20 of 48 Posts
My e-Niro "4" was not used for six days and the UVO app started reporting the 12volt battery as "caution". Alarmed I charged up the 12 volt charger with my intelligent battery charger, but I estimate it only took around 8 to 10 ampere hours before the 12 volt was full. The UVO app still reported "caution". After a run of around 28 miles it started reporting normal again!
Does anyone know the messages reported by the UVO app - I have discovered "normal" in green and "caution" in yellow. Is there a message in red?
Any suggestions why it was still reporting "caution" after it was apparently full?
Did you check the voltage of the 12v battery when UVO was saying caution?
A good question but no. I do not think I have the means to do that. As far as I could see SoulEVspy does not have 12volt battery voltages and I do not have a volt meter. On the other hand I have never known my intelligent battery charger to stop charging before the battery has reached full voltage.
It’s just that measuring the voltage is more indicative than measuring the Ah and is likely what the app is monitoring.
How did you measure the Ah you put in, by the way, and given that the battery would be taking maybe 2 or 3 amps as it got close to charged, that must have taken quite some time anyway?
As for the app not picking up the recharged condition until you next went out for a drive, that doesn’t surprise me, mine often loses contact with the car.
In general and IME, because it’s so easy to damage an AGM battery by letting the voltage fall I think these reporting systems err on the cautious side. You’ll get a low warning we’ll before the battery drops to 12v in most cases, and a short drive will top it up.
2020 BMW i3S 120Ah BEV
Did you charge the battery using the -ve terminal on the body or directly across the battery terminals?
Thanks very much for your full reply.
The ampere hours were estimated from the fact that the charger was charging at 2 amps and took less than 4 hours to be fully charged - at least as far as the charger was concerned.
As far as I know the UVO app had fully contacted with the car - it showed changes in the traction battery accurately but still showed the 12 volt as "caution".
I thought my 12volt was doing fine - but I will now have to watch it a bit!
Thanks for the question.
I charged it (as suggested in the charger instructions) with the negative connector connected to part of the car's metalwork. The charger checked the connection and said it was OK.
I would think 4 hours at 2A probably does simply indicate a lowish state of charge.
I haven’t had this issue with the Niro but my XF, if stood for more than a couple of weeks will give me low battery warning. Always starts easily enough and after a 15 min or so run, will be fine for another week or so. If I put my smart charger on it will take 3-4 hours to show all green.
I’ve checked the battery voltage at the time I’m getting the message and it’s been around 12.3/12.4v, which indicates it’s about 25% discharged.
That’s just to illustrate that the voltage doesn’t need to fall too far to trigger a warning, though an AGM battery is considered as fully discharged at anything much below 12v of course.
Good stuff. This is important as otherwise you bypass the battery state monitoring device and it'll never know that the battery has been charged. So it should be ok.
12.3ish volts should be fine for "ignition off" state.
I find that smart chargers are often too smart, however, and need to let them run a lot of charge/rest cycles before they properly top off a modern lead/acid battery, particularly when they're trying to peer through the murky resistance/reactance of a battery monitoring device inline with the battery itself.
In answer to one of the original questions yes there is a warning message in red.
My reference is Bluelink for my Ioniq but the apps appear to be the same .
I had a yellow 12v battery warning before putting the car on a 6hr 7kw charge. As the 12v battery charges when the car is charged I expected the 12v icon in the app to turn green when I checked during the charge but it didn't. Refreshing the app did not change the state. It didn't turn green until the car was switched on so looks like everything is refreshed when the app queries the car.
My UVO app is reporting Normal for the 12v battery which seems to be ok. I remember Andrew Till had a major battery fail in one of his videos so I bought a cheap little gizmo from Amazon which plugs into the 12v point on the E Niro and it gives an illuminated display of the battery's voltage and two USB sockets. Seems to work for about £4. Probably OBD would give a more reliable reading but haven't gone down that route yet.
Those are ok, but trouble is the car has to be on in order to power on the power socket. So the Voltage then displayed is changed due to charging (Or discharging in Accessory mode) current. You don’t ever see the natural, at rest, no load battery Voltage. A far better 12V monitor gizmo is one of these. I can’t praise it enough!....
Fit and forget. Then read last month of battery Voltage graphs etc, whenever you want. I can read mine from inside the house (just). No need to open the car.
Peter
@prawlin Would you mind sharing the details of how you managed to fit your BM2 device please? I tried to fit mine, but couldn't find a way to then close the cover over the positive terminal. I don't particularly want to start cutting the cover, and don't particularly want to leave it flapping about. Many thanks.
I've had a problem with my 12v recently. I do have a dashcam permanently live, so do use a relatively lot of power. I'm nearly always showing the Red Warning on the Uvo app.
Last Week, after 2 Days of no use, I had a totally flat 12v battery, so I charged for 12 Hours with the intelligent charger until it showed full. The next Day I did a short journey and after that, the app showed Green for the 12V. By the next Day, the 12v was showing Red Warning again. By the following Day, I went to activate the pre-heat and the app showed totally flat batteries (it shows the main as flat when the 12V is flat), however the pre-heat had started and the Green light for charging 12v was flashing.
It seems with the relatively short journeys and a lot of 12v use with the dark Afternoons, the car isn't charging the 12v enough. I've started using the pre-heat several times a Day as it seems to charge the 12v when in use.
There's another long thread here with more info on when the 12v battery charges. Perhaps you need to change to a deep cycle battery, that might help a bit.
You are new to the thread, do you have the battery maintence mode (battery saver) enabled? (I may have the words wrong after all the hand wringing there has been on this subject).
Greg
Set the car to utility mode as described in another thread, it'll do a proper job of charging the battery.
That being said, user @prawlin has done some research into how the 12v is maintained and the process looked quite airtight. The fact your battery gives a warning may mean that either 12v maintenance is not enabled / not working properly, or your 12v battery is at the end of its tether.
So, clearly he leaves the cam on all the time, so would you recommend utility mode whenever leaving the car for any length of time?
Greg
1 - 20 of 48 Posts
