Thanks very much for that. There is no radiator protection at the front. And the buttons I have been told that thay are switched offDoes seem to have had rather a lot of charge ports replaced! I've only had one, at 3 years old on my 2012, just after I bought it. The design changed at some stage, as there was deffo a design flaw in the first version. Mine failed with a short circuit inside it, I think they cracked a bit & water got in.
The rubbery seal is badly designed; any time you charge when it's raining, that rubbery cup collects water. If you fail to dry this after the charge, and simply shut the flap, you're pushing a load of water under some slight pressure right into the electrical pins region! Asking for trouble, and may be why 4 replacements were needed. I always carefully dry the inside of the entire flap area, seals, metal bits, after a rainy charge, before closing the flap. I also clip a largeish, stiff polythene bag onto the charge handle to act as a tent to deflect as much water as poss away from the charging handle & entire flap area. Dunno if this is needed, but it makes me feel better & more confident that I won't get a repeat failure! 2nd charge socket has lasted 5 years now.
I wouldn't worry about it myself. If you buy it, make sure it has a grill fitted to protect the radiator behind front numberplate - this is unprotected, = expensive fix if it gets holed by a stone. Many have holed. Including mine, before I bought it. DIY plans on here to make & fit your own grille. DIY kit available on eBay if the door-handle buttons don't lock/unlock the car, so don't worry about that (but do use it to knock a few quid off!).
Thanks very much for that. There is no radiator protection at the front. And the buttons I have been told that thay areDoes seem to have had rather a lot of charge ports replaced! I've only had one, at 3 years old on my 2012, just after I bought it. The design changed at some stage, as there was deffo a design flaw in the first version. Mine failed with a short circuit inside it, I think they cracked a bit & water got in.
Great. Thank you. Its very useful to know. Ill try to look for something yonger with less millage. I wase thinking about this one. They are quite far away from Edinburgh though.Hmmm you can switch off all except the drivers door, they are controlled from the menus on the centre console. Its likely some do not work, normal problem. Radiator grill usually means not visited the forum, most of us have fitted some form of protection.
The one in the classifieds is the same model year (MY12). Both are out of the 8 year Voltec warranty.
Might be worth contacting the seller, there are companies that will transport cars about the country.
I think @richtrash knows some or at least can give an idea of the price.
[/QUOTE
Ho you can tell that is MY12 make?
Bob Lutz:That sort of sums up VX - Not a clue what they were selling.
The Ampera (IMO) just happened to be the best car Vauxhall never made!
I'll ask him and find out. Thank you very much for all the info and help. I hope I'll find one finally.@Glyndonian has put the model year in the title of the thread.
I've no idea whats the best one around, but at least with that one you can ask the owner not a salesman about it.
For Autotrader, check the images - you can usually tell the MY from the pictures of the back seat. If your lucky they have a photo of the centre screen showing the lifetime mpg, you can work this backwards to get an idea of amount of EV miles to ICE miles, there is a thread on here with the calculation I recall. Then look at mileage and registration, Anything over 100,000 miles is out of warranty, then 8 years - so 13 plate and later have some warranty possibility. Check the service history - Must be every 20,000 miles or yearly which ever is first and by an Ampera Service Garage not any old garage.
Its all down to you, an out of warranty one can be serviced by one of the HEVRA garages or your local mechanic if they do EV's, Its a type of Astra with some common parts, the engine is the same as the 1.4 corsa. Servicing is count the tires, fill the wash bottle and change the pollen filter then change the oil in the ICE every 2 years.
They are great cars, drive really well and are cheap to run. Mine will go in the end as I need 5 seats for when my son and family come to visit but this will be in year or two due to the current pandemic. I may just keep it and run it into the ground and hire a 5 seat EV when needed.![]()
