Hi,
I have just had a Chargemaster installed by chargedev.
As part of the install, they use a voltage shutoff (not sure of the actual name of the device) rather than an earth rod. If the input Voltage goes over 250v (where normal supply should be 230v) then the supply to the charger is cut.
However, the voltage into my property seems to be constantly over 250v (holds steady at around 253v), so the charger never actually works!
Has anybody else encountered this?
Thanks,
Lee
Thanks,
Lee
