1 - 4 of 4 Posts
· Registered
Is this possible? I want an EV but our drive is separated from our house by a public footpath so I can’t run a cable across it from a wall box so I wondered if there is any company who does a stand that can be installed on our drive instead?
· Registered
MG5 LR, Nissan LEAF 24/40 mongrel and various old ICE
A number of the manufactures offer a stand as an option,
ProjectEV example
and there are a number of good looking posts available on eBay.
PodPoint on eBay
There's nothing special about them so you can just use a suitably solid fence post.
Being nosey, but how easy will it be to run a cable under the footpath? A lot of local authorities allow you to run charging leads over public footpaths will suitable covers.
· Registered
We have a post mounted charger fitted alongside the drive as there was no easy way to fit one to a wall and still get the cable to reach the car easily without tripping over the thing. I just got the post fabricated up by a bloke I knew gave him a sketch and he welded up some square steel box with a plate to fit the charger and had it powder coated. I also added a small solar powered light to the top of this post and that has made a world of difference as it gives enough light to be able to see to plug the car in at night.
If getting a post made up then getting one made with a place to fit a motion triggered light would be worth thinking about as it really is a useful thing to have in the winter. I probably got mates rates for the post but the cost of the thing including the powder coating was about €60. I put the thing in the ground ready for the electrician and just put a piece of flexible cable duct and draw cord in the hole and trench leading to it from the garage with the duct coming up through the postcrete I used to fix it in place. All the electrican then had to do was pull the cable through and up the inside of the steel post so there is no sign of the cable at all which looks neater.
· Registered
This is definitely the way to do it.
1 - 4 of 4 Posts
