1 - 3 of 3 Posts
Hi
Just changed from Leaf 24kw type1 plug to 40 kw Type 2 plug . I believe my wall charger can deliver 7kw up from 3 Kw and I know I will have to change Fuse to 30 amp and cable to 6 square also plug as its tethered cable but what do I do about resistors or are they in plug so I can get 7kw .This is out of my league .I would be very grateful for any advice .Sean
ONTO/Evezy £50 Code: CADA7
If as you say it is out of your leage I would definitely be asking a trusted electrician of your choice to do this for you to avoid damage or injury.
You'll have to get everything checked out to make sure that all the wiring is suitable and that you have have enough power coming into your home to support going up to a 7kW load without blowing your main supply fuse.
1 - 3 of 3 Posts
