1 - 13 of 13 Posts
Went to the petrol station to put some air in the tyres. Filled them to 2.8 bar (40.6 PSI) but when I drove away, the TPMS sensors indicated 3.0 bar (43.5 PSI). Lowered them to 2.5 (36.2) and of course the TPMS now indicates 2.7 (39.2).
So, who's right? The car or the pump's pressure meter?
Kia Soul EV 2020
That's a trick question! :devilish: :eek:
I would trust the TPMS before the pump. But if you want an accurate measurement, you will need a better device, that will cost a lot more, than what you would like to spend.
I would trust the TPMS before any garage gauge. The special dedicated sensor chips used in TPMS are pretty hi tech. I have an old Halfords electronic gauge which I’ve used a few years and always seems to correlate well with other systems. It also reads within say 1psi of my E-Niro TPMS when I first checked it.
Don't forget of course that driving will always raise the pressures as compared to being parked for hours undriven.
Peter
Kia e-Niro 64kWh 4+ MY21
I have a Halfords tyre air inflator, the type that connects to the cigarette lighter socket. I set that to 33.5psi on all tyres and after driving, the TPMS tells me all 4 tyres are 37psi. After driving for about 10-15 minutes even in these cold temperatures that rises to 38-39psi. I imagine in the summer that would be even higher. Next time I check, I'm going to set it to 32.5psi which might bring it to the 36psi that Kia recommend at rest/cold. So it is almost impossible to get an accurate tyre pressure. Just get it as near as possible.
For some strange reason, my fathers 13 year old Yaris had all the air replaced with Nitrogen at its last service. Apparently , Nitrogen doesn't shrink or expand like normal air does.
I often wondered, if you put Helium in car tyres, would the weight saving make it more economical. Just joking :rolleyes:
I have several inflation gauges including a calibrated large scale one. The TPMS system on the Kia, like every other TPMS system I’ve compared, is well within 1psi.
I highly recommend the 78% nitrogen mix. Works well as long as you keep it topped up..........
1 - 13 of 13 Posts
