How far-fetched is this?
  • It has already been agreed for use in Apple iCar
    Votes: 0 0.0%
  • The technology will emerge in our lifetime, along with flying cars
    Votes: 0 0.0%
  • It is basic research with no immediate practical use
    Votes: 5 83.3%
  • Special effects and digital illusions
    Votes: 3 50.0%
  • Other
    Votes: 0 0.0%
1 - 10 of 10 Posts
· Registered
Outlander
Discussion Starter · #3 · (Edited)
What problem is this trying to solve?
Consumers do not buy solutions, they buy fashion ;)
Some ideas of my own: It may enable flight and long distance driving without charging. As the connection is magnetic and not mechanical, there is the option to quickly remove the wheels: may enable cars to fly (leaving heavy wheels on the ground), or may enable hot-swappable wheel/battery combinations. Goodyear present their reasons in the middle video from 3:10.
· Registered
Ioniq 5
OK, you’re trying to be funny.
I get it. Very good.
· Registered
Renault Zoe ZE50
There's no reason why you couldn't do all of this. Why has it not been done before? Electric motors have allowed this. Until now, an internal combustion engine had to drive through a multi ration gearbox to drive a car. The power was then split through differentials and propshafts to get to the wheels. This limited the range of movement of the wheels to one axis of rotation and a bit of tilting for steering. Electric motors don't need a gearbox. It's also quite feasible to have 1 motor per wheel where you couldn't really have one engine per wheel. Similarly, mechanical linkages for steering has limited 4 wheel steer.
Why is this good? Oversteer and understeer can be corrected by adjusting the movement of the wheels. Steering can be tighter right up to turning on its axis. No more 3 point turns. But also cars can change direction without "turning". At speed, cars can "crab" to change lanes, which is more dynamically stable. Parallel parking is also easier if you can move sideways. You can fit more cars in a given amount of space.
Why is it bad? Spherical wheels are wider than round ones, which takes up more road space. We have narrow streets. Spherical tyres are bigger so will be more expensive. The wheel is not attached. So it is easier to steal.
· Registered
... The wheel is not attached. So it is easier to steal.
And if you drive too fast over a hump-backed bridge, you won't even need the thief there to remove it! It'll do it autonomously!! Elon will love it !!!
As my Dad discovered when he did just this in an old Hillman Imp, where the central weld for the dual-Y-shaped front suspension unit had rusted through, and only the weight of the bodywork was holding the sub-frame (if you could call it that) in place ...
· Registered
The REE system replaces the current approach of central single/dual motor and drive shafts with “corners”. The idea of driving along with a yoga ball for each wheel is patently ridiculous and a non starter for too many reasons.
REE’s approach makes a lot of sense as it gives you all the individual wheel control you could want, although you would still have to physically steer.
· Registered
Outlander
Discussion Starter · #9 · (Edited)
Spherical tyres will last longer because the wear is spread around the entire surface, and fewer changes will mean less shipping/changing costs. Spherical wheels could also be immune to needing wheel alignment, so overall maintenance costs could be lower.
It may also be possible to achieve the same stability with 3 wheels instead of 4.
· Registered
Outlander
Discussion Starter · #10 · (Edited)
Funny how that never happened to the wheel in my computer mouse! :oops:
The wheel arches would wrap around so that only part of the tyre is exposed. Presumably the same force that rotates a wheel could be used to pull/push a wheel so that it is not rubbing on any particular section of the body while driving, and to rub against the body to produce hard braking. Fewer mechanical parts could translate into lower total costs.
1 - 10 of 10 Posts
