This video was about an ICE camper, but gives a great solution, I think:
2kW @ 12v = 167A, which is probably a lot more than the traction battery to 12V dc-dc converter can handle.The traction battery itself could sustain it no problem, but can the dc-dc charger?
Even traction batteries on smaller cars such as the E-208 contain 48kwh. This means that I could potentially run a 2kw heater for full throttle for 24 hours. Still, 2kw heating might only be used in very low temperatures. For example is a 2.5kw diesel heater more than enough to heat an entire van in -18C2kw is going to drain your traction battery rather fast, isn't it? I think I would stick with the diesel heater.
That's why I would like to know where to find such information. It is not unheard of having car alternators delivering 150 amps and I read somewhere that the old Nissan Leaf models could charge their 12v battery with 1.8kwh whereas the new ones could charge it with 1.2kwh.2kW @ 12v = 167A, which is probably a lot more than the traction battery to 12V dc-dc converter can handle.
For an indication what is the fuse rating on the output of you dc-dc charger?The traction battery itself could sustain it no problem, but can the dc-dc charger?
I'm afraid of that as well, but had hoped to find some datasheets confirming it. That said, ICE cars don't need much 12v battery power either afaik. Just a short, but powerful burst in the beginning and the rest is more or less same levels as an EV. I would even say that the average EV might use more 12v power as they tend to have many more electronic gadgets.I doubt very much that any EV DC-DC converter is designed to supply even 100amps for any length of time. They are intended to replenish normal 12v usage by the electronics, and other 12v equipment and an occasional top up when the EV is parked up.
This is not a bad idea. We should be able to find fuse diagrams on the internet for different cars to get an idea of their DC-DC charger size.For an indication what is the fuse rating on the output of you dc-dc charger?
ALL 12v power on an ICE is provided by the alternator in addition to it charging the battery back up after starting..I'm afraid of that as well, but had hoped to find some datasheets confirming it. That said, ICE cars don't need much 12v battery power either afaik. Just a short, but powerful burst in the beginning and the rest is more or less same levels as an EV. I would even say that the average EV might use more 12v power as they tend to have many more electronic gadgets.
Wonder why alternators on ICE cars are so over-dimensioned though. Maybe because they can only charge the battery while the engine is running?
40-50Ah is what a Reanult Clio uses as well and the reason is rather that it has to be able to give a high power burst for 2 seconds at startup. Not because it needs all that capacity, but because a smaller capacity lead acid battery can't handle these power bursts. This is also why you can get 25Ah li-ion batteries for your ICE car which will do just fine as li-ion have can handle higher currents. Furthermore, lead acid batteries do very poorly in lower temperatures.ALL 12v power on an ICE is provided by the alternator in addition to it charging the battery back up after starting..
On an EV the 12v battery is much smaller (~40-50AH) because there is no starting requirement. ALL power comes from the traction battery so this is equivalent to the alternator on an ICE.
You aren't going to get kw out of the traction battery for heating without drastic loss of range. You'd need to park up at a public charger every day to keep it charged.
