1 - 4 of 4 Posts
2016 model year Nissan Leaf Acenta 30 kWh, 6.6 charger.
How do you set the temperature that will be used when you turn on the climate control remotely via the Nissan EV app? (not via the climate timer).
I have seen on these forums suggestions that this setting is under the zero emissions menu, but I cannot for the life of me find it anywhere!
Or, does it use the same setting that is set using the temperature control on the dashboard?
thanks!
Zero emissions menu (the blue e button on the bottom right of the centre display) , then settings menu, then its right there under "timer/remote - set climate temp". Page 4-23 of the user manual if you have such a thing.
Hope that helps
My 2015 Tenka doenst seem to have this option and the manual says temp on the timer is pre factory set. Am I missing something?
1 - 4 of 4 Posts
