1 - 15 of 15 Posts
This is on a 2020 Soul but i presume its the same on eNiro hence posting in the Kia general forum.
First time attempting timed charging. It didnt charge the first night automatically, i had to start it manually on the app.
But I noticed in the morning it said "charging schedule off" on the app so thought maybe i hadnt set it up right.
So, re-sent the schedule to my car yesterday evening for overnight off peak charging, with "off peak only" set, and UVO said "charging schedule on".
I didnt plug in last night, however this morning, its now back "charging schedule off" on UVO
So, the Q is, What do i need to do so it will charge at the scheduled times, when plugged in and always have "scheduled charging on" set?
Have I missed a setting?
Discussion Starter · #2 ·
Answering my own Q, maybe it was user error since all seems well now, both the car and Uvo report timed charging is on, and it is working as i set, and only charging between the times I set as off peak.
2014 Model S
Hmm. How long is the car left unused between charges? It could be the classic 12v battery level too low and buggers charging issue the original Souls had :rolleyes:
Is there a physical button inside the car to turn on and off timed charging? Does it have any fancy geo location doodads to only do timed charging at home only?
Not left undriven long at all, I drive it most days. On Sunday i did a 60 mile drive (that should have charged the 12v even if it wasn't before) and it didnt do the scheduled charging. (EDIT: the app says "battery normal" ina nice green colour for "normal")
There is no physical button , you turn timed charging on either via the app or in a car menu, but via the app simply sends it to the car so its the same as if you set it via the menu.
No geolocation fencing I can see and even if there was, it has successfully schedule charged..
What Ive noticed is that timed charging, according to the app, seems to arbitrarily turn itself off and on.
For example I did timed charging two nights in a row after setting it up and that worked. Then, a few days later, plugged in, and it didnt. And i did see the central charging light blinking which means charging is on a schedule so the car thought it was on one. But still didnt charge.
Currently (ha ha) it says charging schedule off though I've never turned it off since setting it.
I"m going to resend the schedule to the car from the app and leave it alone and see if it the schedule switches itself off. And also look in the car menu and see what it thinks.
OK, sent it, it now says schedule on. Lets see what happens over the next few days.
Discussion Starter · #7 · (Edited)
Yep !
So I've just plugged it in (after about 75 miles of driving today) Uvosays "scheduled charging on" and the car says "waiting to charge at scheduled time" so what could possibly go wrong 🤞
I'll be peeved if it doesn't charge tonight !
One thing I have noticed is, Uvo seems to default to showing scheduled charging as off but when you refresh it it shows (hopefully) the true picture so me saying it was off might have been me looking at the Uvo display and thinking it was right. Silly me.
EDIT: successful charge. I'll keep a note if it fails in future.
I've had a couple of 'glitches' with scheduled charging this week. I noticed that charging had failed to start at my set time but then when I went out, unplugged and plugged back in again it started straight away. The first time I wondered if I hadn't got it plugged in properly but I'm pretty sure that wasn't the case the second time. It had been working faultlessly until this week. Could be a bit of water getting in somewhere I suppose with all the rain recently.
Discussion Starter · #9 ·
GRRR. Same here Friday night.
Failed to charge at scheduled time.
Noticed an hour after it should ahve started, tried manually starting, got a failed to charge message.
OK I thought, maybe i didnt quite plug in firmly enough.
Tried once more, and it worked (which sort of rules out not plugged in properly?) but it didnt stick to the timed schedule and continued charging past the off time up to 100%. (The one other time i started manually it cut off automatically)
Both the app and the car said scheduled charging was on.
Next time, I will make really sure to plug in the cable firmly. It was also, as it happens, raining hard outside.
Kia Soul 2021
I’ve had similar problems with the App, so I’ve kicked that into touch and only use it for anything other than scheduled charging, like tracking the car etc.
I’ve set charging hours in the car, together with %charge, plus departure time and these are set the same for every day of the week, also set off peak hours for charging for everyday of the week and haven’t set charging outside of off peak hours.
IMHO the Kia App is crap and is best avoided.
I have an e-Niro and have found that when things haven't worked as expected re. charging, I log onto the app and various things have just gone and reset themselves.
Multiple times I've re-configured things (charging included) and again, after a while - randomly - things have reverted to something I didn't want, change or ask for.
So I gave up and set my PodPoint to only allow a charge for my Octopus Go off-peak hours. That works. Thank goodness at least PodPoint schedules work... o_O
Kia Soul 2021
On many occasions my UVO and now my Kia Connect App regularly change settings.
Things like % Charge going from my 100% setting to 50%, plus the App language setting changing from English to Portuguese.
Despite contacting Kia Customer Service, I’ve yet to get an explanation of why these changes are happening!
Bloody shambles.
Discussion Starter · #13 ·
Just for the record , I did the same as TimBob above, gave up using the Kia's timer and then set it up on my home charger. Its been 100% since then apart from once where some wally (oops) didnt push the plug in properly
If it is new Soul EV 1ST EDITION there is,
“EV” button on the heater panel takes you to the EV menus which is where you will find the t
Scheduled charging options
Discussion Starter · #15 ·
If it is new Soul EV 1ST EDITION there is, “EV” button on the heater panel takes you to the EV menus which is where you will find the t Scheduled charging options
Thats not a physical button then! which was the question asked. As i said, you can do it from the menus.
1 - 15 of 15 Posts
