1 - 8 of 8 Posts
Charges OK on Granny charger but not directly from Fast Charger. Red charging indicator icon is flashing and no AC noises.
Any ideas?.
Presume by fast you mean using the same charge point on the car as the granny lead connects to?
Most likely the charge cable you use for public charge points (type2-type1 lead) has a wire break in it.
Cheers.
I've also noticed sometimes the order in which you plug in the cable and start the actual charge on the unit can have an impact on how successful starting a charge is. Try changing plugging first or mid-start of process and see if that varies your result. YMMV
1 - 8 of 8 Posts
