What do you mean? Is the car unmovable during an 8 hour update? That's ridiculous.Doors are locked.and any lights on cluster shoud be on.am not sure ?
Yes you are unable to use the car while it does the update. If they were rolling out as per how it was meant to be at every quarter, the updates would be a lot smaller and quicker. They could also allow ones that make the car undrivable separate from ones where the car can still be driven. But I might also see pigs fly given CARIADs past record of getting this right.What do you mean? Is the car unmovable during an 8 hour update? That's ridiculous.
That’s the outside estimate, but basically yes it’s an overnight job.What do you mean? Is the car unmovable during an 8 hour update? That's ridiculous.
That's a poor excuse, and it does not take 8 hours to install a computer unless you installing it from scratch or something went seriously wrong. Also, most things in a PC can actually be installed while you are running and using the PC.Something to remind some people of. Although those on this thread already know this.
To download the update, the car needs to be switched on.
To install the software, the car needs to be switched off.
Installing software is like a computer update, you are unable to use it while it is being installed.
The car updates are more akin to firmware updates though, pretty much all PC firmware updates I know of require your PC to be restarted (or at least you can't use them whilst the firmware is being flashed).That's a poor excuse, and it does not take 8 hours to install a computer unless you installing it from scratch or something went seriously wrong. Also, most things in a PC can actually be installed while you are running and using the PC.
I know that, but come on, 8 hours...? That is not restart, that's extremely slow download, update and installation.The car updates are more akin to firmware updates though, pretty much all PC firmware updates I know of require your PC to be restarted (or at least you can't use them whilst the firmware is being flashed).
I suspect it's a combination of them being conservative and using the cheapest hardware they can get away with. I could also imagine there's still some legacy "this will only be installed once" mentality in their software designers which won't help, unlike Tesla which was designed from the ground up to be updateable.I know that, but come on, 8 hours...? That is not restart, that's extremely slow download, update and installation.
Not sure if it’s the cheapest hardware available, but the ID models use 2 x In Car Application Server (ICAS) ‘Computers’ manufactured by Continental (yes, the tyre company).I suspect it's a combination of them being conservative and using the cheapest hardware they can get away with. I could also imagine there's still some legacy "this will only be installed once" mentality in their software designers which won't help, unlike Tesla which was designed from the ground up to be updateable.
I've had those too. I always thought they were akin to satnav mapping updates which was why they were smaller in complexity/size.Smaller software updates that I’ve had since 2.1 have been much quicker, but I guess it’s the nature of the architecture they’ve gone with, of which I don’t know much.
Yes, I suspect also that they used the world's slowest and cheapest chips. My BMW needs a few minutes, and that's perfectly fine and fully acceptable.I suspect it's a combination of them being conservative and using the cheapest hardware they can get away with. I could also imagine there's still some legacy "this will only be installed once" mentality in their software designers which won't help, unlike Tesla which was designed from the ground up to be updateable.
