I would like a stronger regeneration in B mode.
Pressing Ok doesn’t work on mine - tried thatPress OK when the phone rings.
And Waze. Plus allow all Satnavs (Google, Apple, Waze) to control the ID light.Allow google navigation to use the VR head-up display through Android auto (if this is a VW issue).
Good choices. Those would actually be great.A geeks page showing which parts of the car are consuming energy, traction, climate control etc. Regen figures.
Battery percentage on the steering wheel display all the time.
Our Polo GTI+ has such a geeks page, called "convenience consumers". It indicates that the aircon is always on to a small degree when airflow is mainly directed at the windscreen. May not be the case with the ID3.Good choices. Those would actually be great.
The Golf 8 loaner I had has a steering wheel heater haptic button on the steering wheel. There’s an idea😉Heated steering wheel button on all pages of the climate control.
kWh used for charging rate, you want to know that your car is charging at the rate that the charger can deliver without doing sums.
Ability to order your favourite radio stations easily
Ability to set the car so it defaults to changing the near side mirror position in reverse.
Remember your climate control settings when it starts, including that you have turned it off!
Ignore speed signs on slip roads when you are on the main carriage way!
Nasty stutter you've got there, you should do something about itFix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, fix wireless CarPlay audio stuttering, and add a 'magically grow new rear speakers' menu button.
But mostly fix wireless CarPlay audio stuttering.
