New to this forum so apologies if most of this has been covered on previous posts.
We have two EV's (BMW IX and Mini electric) using Octopus Go Faster (5 hour tariff) and a 7kw Sync EV wall charger which is set to smart charge either car during cheap tariff. We also have solar and battery storage system where we load up to 10kw of cheap electric each night. Our current tariff ends in June and can see that we can either change to Octopus Go 4 hour tariff at 12p or Octopus Intelligent 6 hour at 10p. It looks as thought the Octopus Go faster is no longer available which is a shame as we use the earliest slot from 9.30pm which is great for manually putting on other appliances.
Just some questions on Octopus Intelligent if anyone can help
1. I can see that both the BMW and Mini are compatible with Intelligent. Does anyone else use Intelligent for either the BMW IX or Mini successfully?
2. The BMW is charged most days and the Mini only once per week. Intelligent says it's only compatible for 1 EV but I have read that other people are on this tariff with 2 EV's. Would we be able to nominate the BMW to pair with the app and but still charge our Mini during 11.30pm to 5.30am using our 7kw charger? I'm assuming we would just do this as we do at present by putting our Sync EV onto smart charge mode for the cheap tariff time and letting the Mini be controlled by our charger.
3. How often does the EV get charged outside of the fixed 6 hour period but still at the 10p rate?
4. How long does it take to change from Octopus Go to Intelligent. Is there any delay whilst test charges are done or can you pretty much start using it straight away.
