1 - 6 of 6 Posts
I’m just about to take delivery of my new 38kw Ioniq in fluidic metal. Really looking forward to trying it out.
In the past I’ve had a Leaf 40 that charged with chademo on the Ecotricity network without a problem, but I hear a lot about Ecotricity’s unreliability.
Has anyone had problems charging their Ioniq 38 using CCS?
thanks
Read Only
The Ioniq should be fine with most of the dual head CCS Chargers, but I think there is still a bug with Hyundai cars on their triple head chargers which causes the charge session to terminate after 6 minutes.
It's only a temporary thing though. Within a few months all the DBT Chargers will be long gone with Gridserve's new rapids installed nationwide to replace them.
Now you have lost the reliability of Chademo, I would say just stick to the alternatives until the replacements are installed. Instavolt and Osprey are a good option. Very reliable, contactless credit card payments, and often 2+ Chargers installed per location.
I generally use ecotricity chargers. There is a standard 45 time limit on them and I think only on one occasion it has stopped before then.A couple of times I have turned up and could not make a connection.. Even if apps say the charger is not working when you turn up it is on free vend and works.
Problems are although multiple connectors on charger (CCS/chademo/AC) only one car can charge at a time .but said above new chargers are coming and with multiple posts and I believe the newer chargers will charge 2 cars at once, so looks like bye bye free vend.
Thanks everyone... I'm about to change from a Kona 64 to an Ioniq 38 as we don't need the range anymore. Looks like I don't need to avoid Electric Highway after all!
Anyone else had any problems?
Cantanalegod - 43kW seems a reasonable speed in the early stages of charging, with a smaller battery than the Kona, a lower charge speed overall isn't something I'm worried about. Thanks.
Some of the early Ioniq 38s will be subject to the battery recall/swap/whatever that the Konas are going through. Have a trawl on ioniqforum.com, details of the car build-dates & numbers are in there somewhere! Mine's a 2019 build, probably one of he first 38s, so is affected. H recommend stick to max 90% SOC charging until it's sorted. FWW although a few Konas caught fir while charging, as far as is known no Ioniqs have. So I'm not losing any sleep!
1 - 6 of 6 Posts
