21 - 28 of 28 Posts
Hi guys i think i might of managed to cure this problem the other day i noticed that the 2 stoppers on each side of the tailgate where uneven one was screwed right in and the other only about half way so i screwed them both in as tight as i could this made the issue far worse so the rattle got worse than ever so i unsrewed both until they where almost removed and then screwed them back in about a full turn and now no more rattles it seems to of done. The trick thought id share this with you.
Ioniq Project 45, e-Niro4+
This has been well known for many months and documented on here, but well done for sorting yourself out. Till the next rattle, of course!
Thanks so much - this helped diagnose my rattle and its nearly gone following adjustment. I think these lugs can be pushed in if you’ve fully loaded your boot space and give your boot lid a shuvv to close it…….at least I think that caused my issue where one lug was fully retracted and had to be unscrewed to match the other side.
21 - 28 of 28 Posts
