1 - 13 of 13 Posts
and if so is there a specific model i need to get.
Hi
I am just in the process of starting to seriously consider an EV. i have wanted one for ages but it is only now that vehicles with the stats i want are compatible with the costs i can pay.
We have an octapus Go Faster tariff and just had solar with battery installed.
I would like to only charge the car on my cheap evening tariff from 8:30-1:30 (unless i over ride it)
but at the same time , on my home solar, i would like to charge my home battery and then dump excess energy into the car before finally selling back to the grid as the last option....... So the car needs to have the potential to charge from solar at any point during the day after my home battery is full BUT also fully charge from the grid when i have cheap energy.
is there a charging system which offers such flexibility or will i just have to make do with charging from the grid off peak?
thanks
Best bet would be the MyEnergi Zappi charge point. This can charge the car at the cheap rate times (set on the app), detect solar generation and use that to charge the car, and can probably be set up with a second CT to perhaps use home battery power (caveat - I've not set one up like this - others may have done). The Zappi has far and away the best support for energy management like this, as it integrates with other MyEnergi home energy management gadgets very easily.
I've no connection with them, BTW.
Is your home battery AC or DC coupled? With a Zappi and AC you can add another CT to the cable between the batter and solar inverter to prevent the battery being discharged into the car.
If DC, the Zappi is still a good option but you have to set the "Export Margin" config so that the car charges only when the battery is full, and there is 50-100w watts "spilling over" into the grid.
I think most chargers & cars have the ability to schedule charging, but you should set one or the other (not both) for your cheap tariff period.
Discussion Starter · #7 · (Edited)
thanks for the super fast replies......... @garycat I dont actually know.. i will read the bumpf on my system and find out .....
this is the inverter
so i guess that means it is AC as i am using an inverter ? sorry if i am thick! v edit actually i dont have a clue!. may need to get details from installer.
Zappi will do it but is expensive. It is not going to "pay for itself". Personally I would set the timer in your car for the Go Faster window, and then, if it's a sunny day, plug in the portable EVSE and press the override button on the car. That will push max 2.3kw into the car, which means when a cloud comes over, yes, you'll take a little from your battery, but the cloud will pass, and the battery will top back up again.
Reactions: Bigmike20VT
Ioniq 28kWh
Zappi is good, but you have to be clear which is most important, using all kWh as effectively as possible, most cost effective, least stressful. Solar, is it FIT or SEG? If FIT, use it to charge your car, if SEG, consider 5p night-time Go or similar. Cars frequently have timers for charging time.
Hi
thanks
I’m hoping to be in a very similar situation soon and wanting to do the exact same things, so I’ll be following with interest. Please keep us updated with how you get on and what solution you find. I think it should be possible From comments above, and the little research I’ve done into this too.
2020 Hyundai Kona Premium SE 64kWh, Ceramic Blue
Personally, I would talk to The Phoenix Works, they are Zappi & Tesla battery installers, who can install and set it up exactly how you want. Zappi is the best charger for solar PV and can be set using various CT clamps to fill the car from solar (if the car is plugged in) before the battery, or, with the press of a button (on the zappi or on its phone app), charge the car overnight from cheap grid electricity. In my case, I heat hot water first from solar and the zappi 2nd. I can't justify the battery price, but if I had one this would charge after both the hot water, and the car, if present, had taken what they want. The car being set on the dash to 80% to limit its max fill.
1 - 13 of 13 Posts
