agree. I guess we could do the math but not sure I’m bothered - eg if you have a granny charger what woudl be the net result of a longer (but more expensive) off peak period to cover your slower charging? eg with something like octopus go and 5p for 4 hours, if you need more like 8 hours per day due to granny, then the other 4 hours would be 16p/kwh. A combined 11.5p/kwh overall. So if you can get 8hours less than that it would be worth considering. Eg EDF go electric 98 tariff gives you 9p/kwh 9pm-7am and all weekend and would likely be better for those with slower chargers
It depends a lot on how much your charger costs you. My charger cost £339, supplied, fitted, and massively subsidised by the government. Let's say that the charger lasts 5 years (i.e. the warranty period), then needs replaced.
£339 / 5 = £67.80 per year
Let's say I only charge overnight for my commute, 5 days out of 7, 46 weeks of the year:
5 x 46 = 230 charges per year
So the charger costs me 29p per charge, assuming the 5 year lifetime.
Taking your example, 5 hours on 5p/kWh and 3 hours at 16p/kWh, the entire charge of 18.4kW on a granny running full pelt would be 5 hours x 5p x 2.3kW = 57.5p + 3 hours x 16p x 2.3kW = 110.4p, so your total charge cost is £1.68.
The same charge at 7kW off peak would take take 2.6 hours and cost 92p. Add in my 29p for the charger, and the total cost is £1.21, so you're saving 47p per charge in this incredibly idealistic scenario, or £540 over 5 years.
If the replacement charger costs double of the original (assuming the wiring in the house is OK and I can just swap the box, it's probably about right), the saving becomes 18p per charge - less compelling, but it still becomes £207 over 5 years.
I wouldn't go booking a trip to Vegas to spurge the new found wealth, but it's still money I'd happily put into my back pocket.
Incidentally, the break even point is around an hour and a half on the higher rate, so if you can get everything you need on that tariff in 6.5 hours, the granny works out about the same.
So many assumptions in this maths that it's probably meaningless, but I'm at work by myself on a Sunday and need something to do to entertain myself during my lunch break...
Also, the benefit is nowhere near as compelling for my actual situation, as my PHEV has a tiny battery and can only charge at 3.7kW. I was jumping on the grants before they disappeared in the hope that it would be some cheap future proofing. So basically, I'm making a point about cost efficiency whilst also being fully aware that I've not followed my own analysis. I'm fine with it.
