1 - 10 of 10 Posts
· Registered
After 5 years loyal service (including a cable swap I did myself back in February when chaning from Outlander PHEV to Mini PHEV), my ROLEC Walllpod wall charger just stopped working.
On inspection the RCD looks like this...
Can I just swap it out, or is this indicative of a wider problem ?
And should I swap like for like, or is there a better RCD I could install ?
Product Electrical wiring Electrical supply Wire Electronics
· Registered
Replace with an equivalent Garo unit, re-prepare wire feeds and ferrule them to ensure permanent secure connection. Not had any problems since (y)
Thanks - looks like this one is recommended - Garo RCBO 1+N 40A char B 6kA Type A
do you know if this is a direct replacement - i.e. wiring placement the same and fits in the "window" in the housing ?
I ask as by the time I strep the supply cables and add ferrules, I dont think I'm going to have much cable play ...
· Registered
Looks like you have enough spare cable as long as you don't go nuts but yes, it should be same fit
· Registered
Does this video still exist in the archives? I’d gladly host it seeing as EVMan packed up his balls and went home.
· Registered
hmm.. emailed ROLEC and replacement will be with me tomorrow - which I presume will be a C40...
not sure if I will use this (it is free after all) or buy the GARO
Buy the Garo. There have been examples of the replacement Rolec type failing as well. You could of course sell the new Rolec to recoup some of the cost ...... :devilish:
Reactions: Phanco
1 - 10 of 10 Posts
