1 - 20 of 386 Posts
I always do one and although the car to me looks perfect, I’m already looking for things to do to it....
anyway - the starting point
pug e208 GT Line in Faro Yellow
129121
129122
looks great from all angles :)
some nice design points
129123
Subtleness on the front facing radar
129124
the “nod” (albeit nothing actually like) the pug 205 c pillar detail
129125
the bi-colour pug emblem front and back
129126
Combined with the retro model badging on the nose
129127
those lovely 3D rear LED lights
129128
and obviously the sabre tooth design DRLs paired with the the full LED headlights on the GT Line.
129129
gloves with the cable
129130
foldable wheel chock is a nice touch.
And I’m sure I’ll find more things as I discover the car :)
JJ
Discussion Starter · #2 ·
So the first little addition - my aftermarket TPMS (tyre pressure monitoring system)
this is a blaunpunkt kit and was about £70. most cars have systems - But they don’t give you real time readings and only tell you when the pressure is lower than you last set it at (if you remembered to do it and know what that pressure was)
this system just has a small system that screws onto each valve stem
129131
and each one then transmits pressure data to the receiver
129132
the receiver plugs into the 12v socket and has an screen that can be angled
behind the screen in a USB socket and the button to change between PSI and BAR etc
batteries last about 4 years (depending on distance driven I guess)
this system has saved 2 tyres since I’ve owned as it beeped at me as soon as the pressure dropped and I could see exactly what was happening (ie it hadn’t just dropped a bit because of the cold) so pulled over immediately
JJ
Discussion Starter · #3 · (Edited)
Dash cam fitting and thanks to @MarkP for the steer
As mark said in his post, the fuses are almost impossible to get to (god knows how anyone thought this was a good design when they swapped the steering wheel to the RHS)
so to make it easy - remove the glove box
3 x clips under the glove box that holds some fabric trim that holds the LED footwell lights
129167
and remove the hex screws plus the 3 on the top edge of the open glove box and the 1 x hex where the fuse cover is.
the glove box is then only held in with 2 clips each side and can just be pulled out with a sharp pull
here you can see the 2 clips (the plastic feeds into the metal
129168
Once it is out you can see the fuses (just)
129169
but you can now get to the from underneath
the 2 accessory 15 amp fuses are bottom left
129170
(bottom is the left this image - helpful)
129171
129172
i went for #36 as I struggled to get to the 2 x blue ones and it works fine (luckily as I have no idea what the fuse does and isn’t listed in
remove fuse and place in piggy back fuse and put back into place
and I used the bottom left fixing of the dash for the earth point
129173
Then all you need to do is feed the cables up the a pillar
remove the dash end panel (it just pulls off)
129174
129175
Then unclip the airbag switch
129176
Then you can feed the wires through the end of the dash and to the base of the a-pillar
129177
129178
I removed the rubber door seal to facilitate the cable fitting in nicely
then you can feed the wire all the way up the a-pillar plastic, around the top and along the headlining - easy.
129179
finally, tidy up all the excess wires
129180
And finally put the glove box back together
this is the view from the outside (not liking the grey self adhesive pad)
129181
JJ
Good images to make it clear. I agree it’s not really been designed for easy access to the fuses, it’s all you can do to see some of them, let alone reach them through the access panel. You can get to the two fuses 31 & 32 if you press that blue connector out of the frame. It’s just held in by a plastic type tree peg, and on our car it had fallen out already! Easy to press back in with the glovebox removed, a nightmare with it fitted!
@MarkP
Yeah considered that BUT you can go in from underneath rather than through the hole
this gives you the ability to grab the fuse with the grabber more easily ;)
did I use the same dart point as you?
JJ
Thanks mate - hopefully we will start to get more members on this part of the forum over the summer - I do feel like I am in a pretty exclusive club though
Neither the e208 or the crossback appear on howmanyleft yet
JJ
Discussion Starter · #9 ·
Just did a reset of the trip and managed to get 4.3mpkwh by driving sedately
this was at the end of my outward journey
129201
temp was around 10degC with no preconditioning
An average of 4mpkwh would get you pretty close to 200miles
JJ
Discussion Starter · #11 ·
Always struggled on the Zoe to keep it above 3.5mpkwh on the same journeys
Getting an average speed in Bristol that’s about single digits is hard
thankfully corona is helping with traffic
JJ
Zoe Devotee
Is that 130miles range at @90% SOC?
Surprised the car doesn't show live tyre pressure, I just presumed that was a thing in cars now.
Discussion Starter · #14 ·
I’ve been blasting the car around so not representative
I’ve been driving sedately today and I’ll put on charge today and see what it says
not sure what the useable battery is around 47.5kwh on a 50kwh pack
@4mpkwh that should give a range of 190miles
remembering it’s 10degC out
most modern cars use wheel rotation to pick up on deflating tyres
JJ
Discussion Starter · #16 ·
Discussion Starter · #17 ·
Or there is this....
No idea if any good :)
JJ
Discussion Starter · #18 ·
So over right charge using the scheduler from 00:30 and the car is now showing good range (based on all town driving)
129206
The reason for delayed charge till 00:30 is octopus go ... 5p/kWh between 00:30 and 04:30 = £2.35 (for a full charge from 0-100%)
see my sig panel for a referral link
JJ
If I was going to buy an e208 it would be in yellow and I'd gloss black the wheels - matching the black details (especially the light 'band' across the back)
1 - 20 of 386 Posts
