361 - 371 of 371 Posts
Corsa-e 2020
God the clock in the e208 looses time quickly
I think about 1min every week
anyone else noticed this?
On the Corsa-e the clock can be set to synchronise with GPS from the nav so it never needs adjusting (except twice a year for daylight saving time). I would have thought that as the e-208 is basically the same infrastructure as the Corsa-e, this option would be available.
Discussion Starter #362
I don’t have nav ;)
JJ
I use the programmed preconditioning.
However, the other morning when my car was on a timed charge, it coincided with a preconditioning event, when I got in the car I discovered it had ceased the charging.
Odd, because I know you can plug in the car to charge and heat or cool the cabin. Obviously a software programming issue which missed out on certain owners useage patterns. A bit like preconditioning fail when below 50% SOC.
Peugeot e208GT, VW Golf GTE
I seem to remember reading that after a certain number of instances (two or three times?) where the car is not used after the programmed pre-conditioning, it will cancel the future program.
Discussion Starter #370
Aw it sucks being winter AND lockdown
I can’t drive the car
I can’t fiddle with the car
I can’t wash the car
I have got an indoor security camera to keep an eye on it though :)
139911
not bad for £30
ended up getting a 2nd for the back
obviously being inside glass the IR is no good but the low light is fine
139912
and it detects the foxes and cats and milkmen and and and
£30 (well £60) well spent
JJ
evezy referral code d6540
Does it record?
