1 - 20 of 26 Posts
I know I should have read the manual, but finding little easter eggs like this after 12 months is amazing. Just in case anyone else hasn't read the manual and doesn't know, if you push the light stalk away from you 3 times, you get automatic high beam assist. Don't know how good it is yet, but itching to find out. :)
3 times? Mine just requires you to push the stalk away once to turn it on provided the lights are set to auto.
BMW i3 60ah bev, solar orange
In my Ioniq, you just push the stalk once. In almost all situations, I've found its as quick to switch them off and back on as if doing it manually. Only thing I don't like is it turns off as I turn right on T-junctions, possibly due to glare from road signs as I approach.
I'll try that later when it's dark. One push didn't seem to do anything. Maybe I'll read the manual.
Reading the manual is a good idea. I found out how to turn on automatic high beam but I had to resort to reading the manual to figure out how to turn it off again.
It's got 4 wheels 🚙
Well I don't know about Hyundai but I had this on many of my German ICE cars over the years and it is brilliant feature, you just drive on the motorway without worrying about changing the lights. You should have camera above your rearview mirror (look at the windshield) and that constantly monitoring the incoming traffic lights and doing all the work for you 😁 Here I am assuming that this is the feature on your car...
IMO it works very well and wasn’t even listed as an option on the first Kona I had but worked all the same, like you I found by accident as I wasn’t expecting it to be present! It will sometimes dip more often than I would like but it’s very good at not blinding others, or at least I’ve never been flashed to say otherwise.
The only issue I’ve found is lorry drivers coming over the crest of a hill. The camera is poor at picking up the cab-top beacons and it tends to blind lorry drivers, which can make them quite distressed. And they very often their own miniature sun mounted on the front/top of the cab so I tend to manually kill the high-beam when I spot lorries on the crest of a hill. But that happened on my last two Audi‘s. One of which had matrix headlamps, which are otherwise magical things. Quite incredible How they just bend the main beam out of the way to not avoid people.
Always a slight delay with the auto high beam headlights, but been generally impressed with them. Certainly no worse than on my Skoda Octavia which was where I first experienced them...
On another topic of hidden features (unless you read the manual) is the lane assist (or whatever they call the softeare that keeps you in the same lane....) when you have cruise control activated - have been pleasantly surprised with it at keeping the car within the lane on a 20 mile route.
1 - 20 of 26 Posts
