Hi, I can not get my van to charge dash is displaying "danger electrical fault" and the traction battery is flashing low charge. Had it code read and advice from quite a few people is the traction battery is faulty or the inverter/charger.
When I connect to a charger I here the relay drop in and then a click from the top of the motor but then anything between 6sec and 20min the charger drops out but I do not believe any charge is going to the traction battery. I have replaced 12v battery to rule that out and checked most of the connections(where safe).
I have attached the codes that are present I have also attached them as a file to this thread.
Any help/advice much appreciated.
DTC Description
No fault codes
No fault codes
EV (EVC - Diagnose - AT - Prog.nr 0201, VDIAG 04) DTC Description
DTC0420F1 - CAN communication - No additional information - Permanent
DTC030586 - CAN communication - No additional information - Permanent
DTC030581 - CAN communication - No additional information - Permanent
EV (EVC - Diagnose - AT - Prog.nr 0201, VDIAG 04) (after last fault code deletion) DTC Description
EV (LBC - Traction battery - AT - Prog.nr 7504, VDIAG 04) (after last fault code deletion) DTC Description
DTC337317 - High voltage circuit - - Permanent
Fault codes
EV (LBC - Traction battery - AT - Prog.nr 7504, VDIAG 04) DTC Description
DTC303008 - LBC - - Permanent
DTC302104 - LBC - - Permanent
DTC Description
No fault codes
No fault codes
Fault codes
