1 - 12 of 12 Posts
Hi Guys,
Newbie in the ev world , wondering if someone can answer this question..
Kangoo (22kw) can only charge at 3.7kw max, from what I understand. I have noticed a lot of public chargers like the supermarket ones are 7kw type 2, does this mean my Kangoo will not accept a charge from them? Or will it charge but be capped at 3.7? Currently I do not have a charge lead or charge point and am wondering if there is any point in getting one if it wont charge on 7kw stations,
Many thanks in advance..
As Thomas said, it will only charge at ~3kW (I did think it was 3.6kW but I could be mistaken) - you can plug into any 3kW, 7kW or 22kW charging post and the van will only take it's ~3kW. You can even plug into a 50kW rapid but I'd strongly advise against it as it'll prevent cars that need rapid charging from using the charger, and unless it's a free rapid it'll probably be prohibitively expensive.
I take it you're currently charging from the 3-pin 'Granny' charger? If so, you'll find a proper wall charger will be faster as the 'Granny' charger only charges at 2.3kW
Banned
Well no they said they had no charge lead - I would say a granny would be fine - but yes @Coop69coop plug it in at the supermarket. Just make sure if it's a type 1 connector on the van that you lock it in with a padlock - if it's type 2 then cool it auto locks on the car
By the specifications, it should be 3.6kW (3.68kw technically; 230V * 16A); but there will be charging overheads and losses, as well as variance on the supply voltage, so it's likely to be more like 3-3.3kW
Ok thanks for all the answers guys. I have had the van a few months now so have worked out most things!
I am loving it tbh. Its a facelift model so its type 2 connector, and I am regularly charging at my local supermarket. There is no battery lease eithet which is sweet, it has SOH 100% and its done 63k miles.
Easy 50 miles plus range. I have made the decision to not get a charge point installed at home, I would only be getting one kw more than on the Granny and I believe that the installers are making a lot of money out of the government grant and I dont want to line their pockets further with my cash! I do 90% of my charging at work anyway , again on the granny.
Hi
Coop69coop
Can I ask if you are getting 50 miles plus throughout the year?
Is there a big difference in Winter/Summer range for you?
I've just purchased a 33kw kangoo and I'm getting aprox 130-135 miles out of a full charge. I have a 7kw charger and it takes just over 5 hours to fully charge.
Darren
Many thanks.
I have just joined the EV world... I picked up my Kangoo Maxi i yesterday.
I drove 85miles home.
With 35 miles range remaining.
I have no granny cable and my home charge point is a month away at least...
I need to sign up to the Scottish charge network...
And possibly pick up a granny cable in the interim..
I went to charge up last night at the local Railway station.. but you needed an RFID card...
@G_Cam you will need to get a Charge Place Scotland (CPS) card - this is especially useful as a lot of the Scottish charges don't have reliable comms so cannot be started remotely. The card only takes a couple of (working) days to come.
I'm not sure if you can use CPS chargers from the app/website, as I've always used an RFID card because this method is much more reliable at starting and stopping the charging sessions
Many Thanks
I have signed up and paid for my card so hopefully it will arrive soon.
After many attempts to get the app to work I have given up to be honest!
Can I ask what happens when new chargers are installed.. There is a new one a few miles from me. Its up and running but not appearing on any of the maps yet. It is in a Council run car park..
Graham
Discussion Starter #12
I am guessing you guys are both 33kw! My 22 does 80 in the summer and at least 50 in the winter. I would like the extra ten kw but I cant justify ten grand on top to get it, my van only cost 4100 which is looking like quite a good investment. I wonder what will happen to the values of these vans as the world start going EV , because at the moment, there is no doubt they are going up in price.
1 - 12 of 12 Posts
