I’ve just bought a 66 reg Zoe. Regarding the key card/fob, what are the benefits in putting it in the slot by the gearstick?
Somewhere to put it, you know where it is.I’ve just bought a 66 reg Zoe. Regarding the key card/fob, what are the benefits in putting it in the slot by the gearstick?
Me too - then I saw someone else mention inserting the keycard in the slot!Ended up cancelling a charge at services trying to open the window
JJ
I just put mine in the cubby hole over the glove box - or in my pocket. I've never put it into the slot and only would if wanting to open a windowI’ve just bought a 66 reg Zoe. Regarding the key card/fob, what are the benefits in putting it in the slot by the gearstick?
Yes - that's because there is a physical key inside the fob (white knob unlatches it) and you can put that somewhere to start the car. But you can also put it in the slot like you saidThe slot uses a different technology to connect to the key than the wireless system - to it does have uses. Should still allow you to start the car with the fob battery entirely dead
