Hello everyone, i have 2020 kona (top trim, with 11 ac obc / i’m not from the uk, so top trims are different to the uk version. Also, pardon my potential bad grammar, english is not my native language).
A bit more background before i delve into the problem. I’ve had the car for 3 months and a solar array (10 kwp) plus a single phase fronius inverter for 2 months. I have also installed a webasto pure charging station which has been connected directly to the inverter (max 7.2 single phase). In the car settings i’ve selected the current to minimum so i used to get 4.2kw (this way i would charge mainly from what the pv array was producing). All was well for the last two months, until yesterday when, whilst charging, i heard a loud bang and the house was left without electricity.
I went and checked and saw three breakers had flipped: the main fuse outside (50A), the inverter breaker (40A) and the wallbox fuse (32A). I reset them and tried again, with the same result: a loud bang.
I called the company that installed the wallbox and they said it looked fine and said it must be the car. I wasnt convinced so i went to a public charger and tried charging on ac. The boom that followed made the public charger reset itself.
so i went to the hyundai service center who assured me they would fix it immediately. So they read the obd for fault codes, found a “low voltage while charging” error (they refused to print it out), said they reset/deleted it and sent me on my merry way, being convinced it was solved. I stopped at the first public charger and tried again and of course the result was the same, i had bricked another charger.
i tried at a different charger to dc fastcharge and that works flawlessly, but im guessing its the ac/dc inverter thats dead.
i will leave the car at hyundai on monday and they will start “ripping it open”.
Does anyone have the slightest clue what has happened ? I’ve yet to discover a similar problems on the “internets” that’s similar to mine.
Thank you in advance for your input.
