In the older cars it's in the EV display. Just tap the one you want to change and it brings up a setting screen.I recently had my Kona 'in' for a software installation.
It is now charging to 100% instead of 80%.
I cannot find the setting to alter this in the car?
Can you help?
Does anyone know what this recall was for?
OK, needs someone with the new version to weigh in.I got my car last Summer - new.
I tried tapping the screen but nothing happened!![]()
Try setting it through the bluelink app if you can't find the setting on the head unit.I got my car last Summer - new.
Which is the 'EV section' on the display?Mine reverted to 100% after the service. Tap the EV section of the display: In the lower left corner is charge management: Tap on that and select the third from the top to set the limit for DC and AC charging.
I looked at the app but there is not an option to change the setting.Try setting it through the bluelink app if you can't find the setting on the head unit.
I tapped on the 'battery' but nothing happened?
Most obliged Duncan.View attachment 141620
It doesn't seem to remember and display the charge limits but it does update them in the car when you set them in the app.
