Hi all
does the hyundai Kona come with a type 2 charge cable?
Many thanks for any replies![]()
It certainly used to, but you need to check the latest specifications on the website to be sure (and take a copy). It's the sort of thing manufacturers or importers can change on a whim.Yes. Also a granny charger, both 5m long. Well at least the 2019 model did. I doubt this has changed.
thank you SKeen34 i could not remember if i read that it came with it or not, getting my Kona Premium se delivered on wednesday (lease)I took delivery in July 2020 and it came with both the Type 2 and the 13Amp charger. Both in bags with the 13Amp stored below the boot floor.
My July 2020 Kona also came with both. With a little care, the Type 2 cable can also be stored under the boot floor in the Kona, just behind the rear seats and in front of the polystyrene trays. This keeps the boot "proper" completely empty.I took delivery in July 2020 and it came with both the Type 2 and the 13Amp charger. Both in bags with the 13Amp stored below the boot floor.
i have just bought the 2020 kona ev. it comes with a mains point charger and a heavy duty cable for a rapid charger. the mains point charger is type 1.Hi all
The default storage is not goodWith a little care, the Type 2 cable can also be stored under the boot floor in the Kona, just behind the rear seats and in front of the polystyrene trays. This keeps the boot "proper" completely empty.
Surely you mean type 2. Because thats what the Kona is type 2/ CCS.i have just bought the 2020 kona ev. it comes with a mains point charger and a heavy duty cable for a rapid charger. the mains point charger is type 1.
Oh no it's not! (Christmas is just around the cornera heavy duty cable for a rapid charger.
i have the 2020 hyundai kona. i am presently charging at home via a 13 ampp socket and always using the in cable charger set to the lowest setting of 6 amp. i feel this is safer even though it takes much longer. i have the rapid charger cables in the boot ready for a longer journey. hope this helps / linndley brookHi all
