1 - 11 of 11 Posts
Really excited to pick up a second hand leaf 24 next week and have got a question about charging rates...
How many miles an hour will I get from the granny charger? trying to work out if my daily commute will fit in with the octopus go 4 hour window
I've got a charged EV 7kw charger but this leaf doesn't have the 6.6 on board charger so decided against a type 2 to type 1 adapter.
Thanks all
Leaf 30kWh, Outlander PHEV
On my Leaf30 granny charger charged at 1% every 7 minutes compared to 1% every 5 minutes on 3.3kW triffids dedicated charger.
In Winter 1% required to 1 mile on occasions. 8 miles compared to 12 on dedicated charger.
Using 3 pin isn't good for long term use unless the wiring is dedicated as home wiring can not sustain 10A continuous discharge.
More miles and less likelihood of catching fire.
- Leaf 30 kWh
If you want to fit as much charge into a 4 hour window, it might be worth getting a type 1 - 2 cable. You're going to want one to recharge at public charge points anyway.
Don't forget preheating also uses charge faster than a Granny charger can supply it so you'll run the battery down further in cold weather.
16 Amp type 2 to 1 leads are very inexpensive on eBay etc as few people are buying them now. Wait for a bargain.
Unfortunately my 7kw charger is tethered so for the time being I've bought an extension lead from toughleads and requested a 5hr window from octopus which should cover the commute mileage View attachment 129773
Requested a 5hr window from Octopus? Do they even do that? I'm with Octopus on the same tariff by the sounds, didnt realise that the time slot was variable?
Discussion Starter #9
Y
Yes it's available if you ask, it's called go faster, they have different time slots too. I chose to have mine start at 2230 but before it started I made a switch to octopus agile instead, gonna see what the agile bill is and compare that with the Go tariff. Think my Go tariff averaged out at 10.50p
Y
Thats really interesting, I didnt even know they did that. Do they still charge 5p a unit for the set hours? like the Go tariff?
1 - 11 of 11 Posts
