Hi,
I recently purchased a LEAF 40kWh from a car dealership (nameless for now as I'm currently working through their internal process although their latest stance is 'nothing we can do').
It was a high mileage car, advertised as 124k. When I went to pick it up after paying for it and giving it a brief once over, I then realised it was actually 136k. I couldn't not take delivery as I needed a car. Their response was that they were misled by the person who traded it in, and so there was nothing they could do but apologise and throw in a set of car mats.
The person who traded it in had also taken out both charging cables, but the dealership did provide me with a replacement Type 2 cable.
Once I got it home I noticed also that the tyre repair kit was missing from the boot.
All of this is annoying but it wouldn't prevent me from using the car necessarily. However, I then discovered, after covering a few miles, giving it a couple of rapid charges, then charging it on type 2 up to 100%, that there's an issue with the battery pack.
I drove with 100% and the battery behaved normally, pretty poor consumption of 3miles per kWh, but otherwise fine. However, once it got just under 50%, I noticed that the battery percentage figure started to drop, and then bounce around based on acceleration amounts. It went down to 40, 30, 20, 15, then back up to 35, and back down again under acceleration. All this within the space of a couple of miles of driving.
I've taken a screen recording of LEAFspy whilst accelerating for short bursts to demonstrate the issue. The LEAFspy video shows the battery percentage as steady, however, it was jumping around under hard acceleration, and it ended as showing 19% on the dash reading. I've also shown the battery at 100% charge after a Type 2 charge (the screenshot doesn't suggest 100% but the dash does and it was plugged in for 8hours so it's definitely full).
Is this indicative of a completely cooked battery? If so, with it being a 2018, would it be covered under warranty? It hasn't always been serviced at a main dealers according to the paperwork but it has been serviced. If it's unclear regarding warranty repair, how do I demonstrate this fault to a dealership which doesn't specialise in used EVs and clearly had the wool pulled over their eyes when they were traded in this car..
Any suggestions/advice would be very welcome.
Screen recording
Screen recording
