That's a bit disappointing. The 40s aren't very old at all. Wonder if it's deformed? Saw a scary thing showing some battery packs having warped with heat
Drives me potty when a dealer say 'well it's full and says it has X miles so it's fine' They can't fathom that cars lie to them!Just an update. Took my car back to my local Nissan dealer today for further diagnostics.They stated they could charge the car up to 100% with a range of 160 miles. I stated charging was not the issue but that my actual effective range was 99 miles in ideal conditions and that once my car‘s SOC was down to 45 %, that my range would then plummet instantly. The dealer stated that the new “diagnostic readings” would be relayed onto Nissan UK. Feeling a bit nervous at this stage,clearly I have a major battery capacity loss. Let’s hope this turn’s out well…
I mean, my 24kwh Leaf once claimed it had 123 miles range, so the number on the dashboard clearly cannot be trusted...!Just an update. Took my car back to my local Nissan dealer today for further diagnostics.They stated they could charge the car up to 100% with a range of 160 miles. I stated charging was not the issue but that my actual effective range was 99 miles in ideal conditions and that once my car‘s SOC was down to 45 %, that my range would then plummet instantly. The dealer stated that the new “diagnostic readings” would be relayed onto Nissan UK. Feeling a bit nervous at this stage,clearly I have a major battery capacity loss. Let’s hope this turn’s out well…
How are your tyres? No signs of uneven wear or under inflation?Thanks for the comments. I might still do a 0-100% charge ( 16 hours at home ) using my Nissan granny charger, to see if the BMS can bring the battery into line whilst trickle charging.I did last week do a 0-100% charge for eight hours at a 32 amp post ( Alfapower network ) but it has made no difference, still only 99 miles of range, or less.
Until recently, all major battery problems went to Lookers at Gateshead (not the actual Nissan factory at Sunderland); Fish of Swindon now have the required facilities for that as well.Just to give an update. The car is to be low loaded on Monday for transporting onwards to Fish Brothers Nissan in Swindon. They will either repair or replace the pack. Evidently other than the main factory only they ( Fish Brothers ) have the expertise with pack issues. All in all good news that I am at last getting a fix as my range this week has been getting even worse ( now 80 miles…or less ! ).
