Had to call the AA out this evening. My wife was driving the Leaf (Gen2 12 months 5100 miles) - backing it out of a car parking space - foot on brake, engage reverse, release parking brake, brake pedal still depressed, car shot backwards. Fortunately she had the presence of mind to stamp back on the foot operated parking brake. Engaged forward - same problem.
Clearly not a good idea to set out on her journey home, so she called the AA.
There was a noise from under the bonnet - the ABS system engaging at the bottom of the pedal travel, also could hear brake servo noise on slight pedal depression. Turning off the ABS made no difference. Pedal goes to the floor.
Connection to the diagnostics showed e-brake failure code, can bus problems, and 3 wheel sensors faulty.
AA man said he could reset the fault codes, but was not prepared to do that because the car was still under warranty, so the manufacturers would complain. His system said he couldn't tow it without a wheel lift - not even slowly with a hard tow bar. So its being collected tomorrow on a flat bed and taken to the local dealer.
Anyway, the reason I am writing this diatribe is that the foot brake did not work - pressure on the pedal did not operate the brakes and bypass the servo - a real safety hazard. This could have caused a major accident had the car been moving at normal speed - dont know whether regen braking would have worked. My wife is still very shaky, and we have lost confidence in the car.
Has anybody else had dangerous brake problems - I have seen various more minor issues - not as serious as this.
Tony
Tony
