1 - 3 of 3 Posts
Hi, As you know a lot of Nissan dealers will not let you use Leafspy to check HV Battery Health prior to purchase.
This happen to me about a year ago.
Get then to give you a print out from their Nissan Consult 3 Plus diagnostics, which they do as part of pre delivery inspection.
This will show current battery charge level (Wh) and SOC %, from this data you can work out the approx SOH.
In my case these were 17200Wh (17.2KWh) at 58.8%. So 17.2/0.588 = 29.25KWh (max capacity).
SOH = 29.25/30.0 =97.5%
After I had bought the car I checked the SOH with Leafspy which showed: 96.95%
See Below
134632
134633
except a new battery only charges to around 28kwh, so not convinced your maths work?
Hi,
Remember, Consult reports Gross Capacity (Max 30KWh) not Net as reported by Leafspy (Max 28KWh).
Leafspy showed 27.5 KWh om my car after purchase.
All I am trying to say, is this is another way of trying to better gauge battery health for a new buyer, when they are not allowed to use Leafspy.
Mark.
1 - 3 of 3 Posts
