Leaf ECO button use ? opinions please
6522 Views 32 Replies 12 Participants Last post by  Drewby80
Hi People
Any Leaf users use the ECO button ? does it do much for the range of the vehicle , any long term benefits ?
21 - 33 of 33 Posts
CrossClimate+ are on my to do list, I want my wear out of these Dunlop’s first though.
Seems daft / wasteful to scrap a perfectly serviceable set of tyres!
Maybe. But driving in snow and ice on tyres that are not safe in those conditions is not a great idea either. We've had a lot more snow and ice this winter than the last couple and the CrossClimate+ have handled it with aplomb. I'm even able to start moving from stationary uphill on un-gritted roads that are un-walkable and are essentially black ice.
A couple of times now I have driven up a road where we have to stop each morning to offload our son and tried to step out of the car and have been completely unable to stand up on the road that I just drove and parked on without fuss. Quite remarkable for an All Season tyre.
How have you found the difference in economy / ride?
The Dunlop’s do soak up the bumps nicely is it a harsher ride on the CrossClimates?
Not much difference in economy, maybe a couple of percent. I only saw a drop of 0.1 miles/kWh on my daily commute when they were fitted in September, which is near the margin for error even for a very repeatable commute.
Dry summer grip is just as good as the Dunlops and cold wet grip is fantastically better. You genuinely feel like you're driving on a dry road in the wet. Snow and ice grip seems at least as good as the Vredestein Quatrac 5 on my previous car, perhaps even better on ice than the Quatrac 5 which was more optimised for snow than ice.
Unfortunately there is no denying that the ride is quite a lot harsher than the Dunlops at least in the Tekna size, I can't speak for Acenta wheels where it would probably be not as bad.
I'm going to assume that the cause is the 95W XL speed/load rating - while they have soft winter tread they have very stiff sidewalls. Tekna's normally take 91V tyres.
I dropped the tyre pressure to 34psi and that's helped a bit, also the ride is not nearly as harsh in winter weather and is almost acceptable, while it was pretty bad on a hot summer day going to the beach for example, where you will see a tyre pressure increase of around 4 psi during the journey.
I was initially a bit gutted about the harsher ride but wondered whether I'm just a ride quality snob after years of driving hydraulic Citroen's! In the winter I'm finding it OK but I'm considering getting some Acenta wheels to put some cheap but comfortable riding summer tyres on for the summer and keep the CrossClimate+ on the Tekna wheels as a winter tyre. I haven't made up my mind yet.
But there is no denying that they perform extremely well from a grip perspective, in pretty much all weather conditions.
I think if they ever did a non-XL load rated standard 91V version of the CrossClimate+ it would be the ideal tyre for the Leaf. Unfortunately they don't at the moment.
See less See more
I was out in 4-5 inch snow this morning, and can say that the crossclimate+ are pretty good in snow (nearly as good as a true snow tyre). I've also found them good in both wet and dry. Someone else noted that they make a 'slithering' noise under acceleration - which i've heard as well, though it's when accelerating 'quite hard' (a relative term...). I saw a bit of a range reduction when first fitted. Ride is OK (on the standard wheels, non-Tekna).
Yes they do make a slithering noise under acceleration even in dry weather but it seems to have reduced significantly now they've worn in a bit and I think all winter tyres make this noise to some degree due to the thin cuts causing the mobile tread blocks to rub against each other under torque - which doesn't happen on a summer tread pattern.
It did bother me a bit at first but it doesn't any more. The ride does still bother me though, and I suspect it's much worse on 215/50/17 Tekna wheels than 205/55/16 Acenta wheels. I sometimes think I would have been better off saving a couple of grand and buying an Acenta rather than a Tekna.
I prefer ride comfort over extreme handling (it's a daily commuter) so would have preferred the Acenta wheels for smoother ride and cheaper tyres, and I may yet buy some Acenta size wheels to put on it...
One of the main reasons I got a Tekna was for the "Leather" seats (we have a messy 4 year old...) and heated seats/steering wheel, but it turns out that the Leather drivers seat is pretty hard and uncomfortable and the cloth Acenta seats probably would have been more comfortable... and because the heater is so much better than the one in my old Ion I don't really even feel like I need the heated seats, after previously deciding heated seats were a must have for my next EV. (Although it is still nice having heated seats)
The birds eye camera view is nice and I do find it useful but it's not a good enough reason alone to buy a Tekna... If you don't mind cloth seats I think the Acenta is probably the sweet spot.
See less See more
I changed my perfectly good originals for these Pirellis. Cinturato ALL SEASON PLUS - Car tyre | Pirelli
They are so quiet I can now hear this sort of rushing noise when I accelerate on a bit of new tarmac. I could never do that before. The ride is better and there is the added bonus of self-seal that's great for the Leaf with no supplied spare or even a jack. They stick like glue to the road even in icy conditions.
The only downside is a) the price £538 and b) the slight reduction in range of about 3 miles per 100miles.
Is the each :eek: or for a set of 4 ?
I only tried the ECO button once and the car performed like it was driving through treacle , and as said very sluggish , Think I will not use it again
Thanks for the comments
No that was for a set of 4...... 😢
See less See more
Tekna size tyres are approximately twice as expensive as the same tyre model in Acenta size. I compared a number of different tyres in both sizes and this seems to be fairly universal across brands.
CrossClimate+ for Tekna wheels are also pretty close to £538 for a set of four and approximately half that price for Acenta wheels. :( One reason to get an Acenta instead of a Tekna for sure. There is also a far smaller selection of tyres available in the Tekna wheel size.
My Leaf is a Acenta Wooopedy dooooo :cool:
I run my 13 Reg Sunderland built Acenta Leaf in ECO mode because I have a heavy right foot and in ECO mode the pressure required on the Go pedal nicely balances the weight of my foot. In non-ECO mode I find that I am having to use my ankle muscles to try and lift my right foot off the Go pedal.
if I use B at 50+ adding Eco seems to make no difference to the regen effort.
In B + ECO mode, just lifting my right foot off the Go pedal causes the maximum 30kW of regeneration at any speed above 40 mph. (In D+ECO this occurs at speeds above 60 mph; and in B+ECO+brake pedal applied max regen occurs at any speed above 20mph).
Reactions: 1
I second this, I run my 2018 40 Leaf in eco mode because i city drive all day as part of running my business and if I can just plant it and let the car worry about applying the power smoothly and sort out the economy that’s a lot less effort than being bothered to actually control it myself!
I also permanently have e-pedal switched on because then I only have to hit the brakes occasionally, is this lazy?
Maybe... It could also be considered smart, after all you don’t wash the dishes when you have a dishwasher, it’s just using technology to make life less bother! 😃
Ye but ye but you have the bother of putting it all in and taking it all out 😮
Was -4c when I did my 80mile round trip an had 14mile left using climate control heater set at 20.5c on eco b mode, 90% a1m at 54-60mph, the up shot is when I need a power boost I turn eco off an the leaf almost feels fast lol
Now there’s a first world problem for you! 😂
I never said it was me that loaded it. 😉
21 - 33 of 33 Posts
