1 - 5 of 5 Posts
Not sure if the below is a positive or negative so going to throw it up there for comment. 2016 model with 30k miles. SOH at 90.73% although from what I've read this may be artificially high due to the 5 or 6 fast chargers last Friday.
Can someone tell me where I check to see if car is running the recent software update for the battery?
123951
For some reason the mileage does not tie with the dash. Leafspypro is showing less than what's on the clock.
123952
Stranger again when I changed the setting to Kms it shows less Kms than miles. Not sure what's going on here..
123953
SoH seems good for the mileage.
- Leaf 30 kWh
Go to the service menu, read the ECU bits and there should be a version next to HV battery. I think if it ends 4A or 4B then it needs the software update. If it ends 6A (like mine) then there is no software update. I think you need Leafspy pro to do this - not the lite version.
I'm on virtually the same SoH as you with only just over 7000 miles.
I wonder is it because the chap I bought it off only ever used the granny cable to charge the car ?
Nah granny charger is a fire hazard good to charge at L2 rather than rapid.
I'm at 92.3% at 24000 miles with 56 QCs
- Leaf 30 kWh
1 - 5 of 5 Posts
