1 - 7 of 7 Posts
I have just replaced the reversing light bulb on my 2021 Kia e-Niro with an LED bulb and what a huge improvement it is - makes the rear camera much more usable at night!
The bulb came from Canada (Auxito) in a pack of two and, as the UK spec car has only one reversing light, I have a spare one!
I can thoroughly recommend fitting this item and if anybody wants this one then it is available for £20, including shipping (or £17 if you can collect from Macclesfield area)
The specs are:
Voltage: 9V-30V
Power: 12W
LED Type: CSP
Color: 6500K White
Socket: 912, 921, 906, W16W, T17, etc.
I believe that it will fit all e-Niros, but, you ought to double-check the fitting on your car matches the details above.
There are videos on Youtube explaining the installation process.
The specs are:
Voltage: 9V-30V
Power: 12W
LED Type: CSP
Color: 6500K White
Hi, do you still have the Bulb
No problem. Thanks. Would you be able to share a link of where you got it from. And is the bulb giving you any errors as a lot of feedback on replacement bulbs say they throw up canbus errors. This is what i could find based on your earlier post. Thanks.
Yes, bought direct from them.
Not seen any errors so far!
1 - 7 of 7 Posts
