1 - 8 of 8 Posts
I somehow managed to crack my left rear light cluster plastic right in the centre. Now I have water ingress and droplets at the bottom of the cluster housing.
My local car yard (Charles Trent) has one for sale at £156. Anyone else think this is a bit much for a secondhand piece of plastic?
Cheers Tony.
Cheers Tony.
Cheapest undamaged one is £130 on eBay, free post, so your breaker's price is not that outrageous TBH
At these prices I would be attempting a repair, e.g. with epoxy resin.
Couldn't agree more. Superglue is my friend......
2011 Leaf with Muxsan 17.6kWh battery, curt tow hitch fitted for bikes or buzz rack P10
I read somewhere that bicarb (baking soda) with superglue makes rock hard filling.
Discussion Starter #7 (Edited)
This taken from my post on Poll for Leaf Tow-Hitch
I have just wired my 13-pin socket into the vehicle and in order to do so I had to remove both the left and right clusters. It was easier than I had thought, but required considerable force on the top part of the cluster to remove it. Just undo the bolts and then yank the top quite hard. The wiring loom has very little slack, which makes it a bit of a pain.
Reactions: EmmaK1
Discussion Starter #8
I took the opportunity to remove the left cluster again and when I oriented it upright there was about an inch of water at the bottom. I drained it as best I could then set up a hair-dryer in the middle lamp socket hole. After 2 hours, the water and mist seemed to only be left in the top part of the cluster. I re-positioned the hair-dryer into the large led hole and let it run for another hour.
After leaving it to cool down, I could see no further evidence of moisture and I sealed the hole with epoxy resin (araldite).
I then re-assembled the cluster to the car.
This morning with the car in the garage overnight I was disappointed to see water droplets on the plastic lens inside.
I will (someday) remove it again and give it another go with the hair-dryer. Grrrrrr!
135412
1 - 8 of 8 Posts
