1 - 4 of 4 Posts
Kia e Niro 2020
Hi all
Where we live there is a car ferry we regularly travel on. However, when turning the car off, the radio then turns off a few minutes later.
How do you keep the radio on without leaving the car 'ready to drive'?
VW Passat GTE
Have you tried Utility Mode?
(Disclaimer: I don't know if it actually helps or how to activate it, I just remember somebody mentioning it here a while ago and I think it sounded like it should do what you want...)
Hi all
Put it into utility mode.
I would just probably leave it in Ready state in P personally (but I’m a lazy old git). If you don’t want to do that then definitely use the very excellent Utility Mode. In that mode everything works inc heater, but car cannot be driven. To drive again you must turn off the car and restart in the usual way.
Whatever you do, never ever EVER use the dreadful Accessory Mode (turning car on without foot on brake). That would appear to give you just what you want but it will flatten the 12V battery in a very short time, guaranteed. And even worse, that partly flattened 12V will not recover so quickly even whilst driving. (The 12V charging routine on these cars is a bit whacky, to put it mildly. it charges intermittently whilst driving continuously. It’s ok for maintaining a well charged battery but is utterly useless at recovering a partly discharged battery!)
Utility mode is great as it will keep everything powered up from the big battery and will give your 12V battery a (probably very welcome) continuous 14.7V top up charge. It can do no harm either.
Peter
1 - 4 of 4 Posts
